iPod question using Windows Explorer
brettw22
I've got my iPod connected to my work laptop with the USB cable, but I can't pull up any of the music on my iPod........
I don't want to sync with this laptop (because it has nothing on it and I don't want to wipe out everything) but I can't find a way through itunes or windows explorer to find my music to play it...........any ideas other than hooking up an audio cable from the computer to the headphone jack?
Post edited by brettw22 on
You need to go into internet explorer properties and select "show hidden files" there ya goHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Ok, I tried that and apparently Apple codes the file names some random 4 letter code that has nothing to do with the actual file name..........so I'm playing the songs now off the iPod via Winamp, but occasionally those 4 letter codes show up as the 'song'..........whatever.....at least it's playingcomment comment comment comment. bitchy.
Get a 3rd party app to explore and drag/drop with the Ipod and Windows. You can do it without, but it's kind of a pain. If you're using anything but an Ipod touch, I recommend www.redchairsoftware.com. Check out Anapod Explorer on their site. Very easy to use and works well.
If you rely want to do it the easiest way. Just unplug you speakers from your computer and plug them into the ipod your done I do it at work all the time. "Um no boss you didnt here Jimmy Buffett"HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
