iPod question using Windows Explorer
brettw22
brettw22 Posts: 7,623
edited July 2008 in The Clubhouse
I've got my iPod connected to my work laptop with the USB cable, but I can't pull up any of the music on my iPod........
I don't want to sync with this laptop (because it has nothing on it and I don't want to wipe out everything) but I can't find a way through itunes or windows explorer to find my music to play it...........any ideas other than hooking up an audio cable from the computer to the headphone jack?
Post edited by brettw22 on
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited July 2008
    You need to go into internet explorer properties and select "show hidden files" there ya go
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • brettw22
    edited July 2008
    Ok, I tried that and apparently Apple codes the file names some random 4 letter code that has nothing to do with the actual file name..........so I'm playing the songs now off the iPod via Winamp, but occasionally those 4 letter codes show up as the 'song'..........whatever.....at least it's playing
  • bdaley6509
    bdaley6509 Posts: 1,167
    edited July 2008
    Get a 3rd party app to explore and drag/drop with the Ipod and Windows. You can do it without, but it's kind of a pain. If you're using anything but an Ipod touch, I recommend www.redchairsoftware.com. Check out Anapod Explorer on their site. Very easy to use and works well.
  • bigaudiofanatic
    edited July 2008
    If you rely want to do it the easiest way. Just unplug you speakers from your computer and plug them into the ipod your done I do it at work all the time. "Um no boss you didnt here Jimmy Buffett"
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
