Quick Question
bigaudiofanatic
Okay my friends car craped out so I spend most of my day yesterday getting the stuff out. He was so upset about not having a car and having a nice system he told me if I want to use any of the stuff until he gets a new car I can. WOW what a friend. So I borrowed his kenwood 10 inch sub the box and the alpine amp. My question is this until I run my REAL power wire can I use speaker wire to power it I will not be cranking it rely loud. I know that I have to install a fuse as well. It's street wire. This is the stuff.http://www.crutchfield.com/App/Product/Item/Main.aspx?g=183450&i=211UCT12&tp=1359
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
Post edited by bigaudiofanatic on
IMHO, 12GA's kinda thin for you to be running your power through it. How many amps/watts (whichever you prefer) are we talking about? If I were you, I'll just wait till I get proper power wires. Better safe than sorry.
.02 hth. -
It is a Alpine MRP-M450. Here are the specs. http://www.crutchfield.com/App/Product/Item/Main.aspx?g=120&i=500MRPM450&tp=115HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
going through the link you posted, even the guys at crutchfield recommend a 8GA power/ground wire...if it were me, I'd stick with that.
.02 hth. -
will do I will order a amp wiring kit at the sight of my first pay check next week. But beofer I do does anyone areound here have one they are not using?HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
i wish you would have asked me that question a few weeks ago.
... but you can usually find 8 or 10 gauge amp kits pretty cheap. -
@bigaudiofanatic
I'd like to volunteer too but I'm offshore, my extra wires' at home and home's half-way around the world from you. good luck though.
tip: patience. ;-) it's almost "next week" already anyway. -
double or triple the speaker wire and u should be okay.2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
Just save some $$, buy a "good" amp kit. Then take your time and install the kit correctly, leaving the extra wire for when you get your own stuff...Mike Bobelak
Heartland Regional Manager
Polk Audio -
Ya I want to get a stinger kit.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Dont use speaker wire to power your amps. Its not designed to handle that much current and besides, its way too small. Walmart has 8 gauge wiring kits for like $20. No excuse not to use one.polkaudio sound quality competitor since 2005
I dont get it, you already told us that crutchfield are the real experts..
so?
http://www.polkaudio.com/forums/showthread.php?t=69894Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
