Quick Question
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited July 2008 in Car Audio & Electronics
Okay my friends car craped out so I spend most of my day yesterday getting the stuff out. He was so upset about not having a car and having a nice system he told me if I want to use any of the stuff until he gets a new car I can. WOW what a friend. So I borrowed his kenwood 10 inch sub the box and the alpine amp. My question is this until I run my REAL power wire can I use speaker wire to power it I will not be cranking it rely loud. I know that I have to install a fuse as well. It's street wire. This is the stuff.http://www.crutchfield.com/App/Product/Item/Main.aspx?g=183450&i=211UCT12&tp=1359
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • B2Bomber
    B2Bomber Posts: 24
    edited July 2008
    IMHO, 12GA's kinda thin for you to be running your power through it. How many amps/watts (whichever you prefer) are we talking about? If I were you, I'll just wait till I get proper power wires. Better safe than sorry.
    .02 hth.
  • bigaudiofanatic
    edited July 2008
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • B2Bomber
    B2Bomber Posts: 24
    edited July 2008
    going through the link you posted, even the guys at crutchfield recommend a 8GA power/ground wire...if it were me, I'd stick with that.
    .02 hth.
  • bigaudiofanatic
    edited July 2008
    will do I will order a amp wiring kit at the sight of my first pay check next week. But beofer I do does anyone areound here have one they are not using?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • black magic
    black magic Posts: 669
    edited July 2008
    i wish you would have asked me that question a few weeks ago.
    ... but you can usually find 8 or 10 gauge amp kits pretty cheap.
  • B2Bomber
    B2Bomber Posts: 24
    edited July 2008
    @bigaudiofanatic
    I'd like to volunteer too but I'm offshore, my extra wires' at home and home's half-way around the world from you. good luck though.
    tip: patience. ;-) it's almost "next week" already anyway.
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited July 2008
    double or triple the speaker wire and u should be okay.
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • Mike B.
    Mike B. Posts: 54
    edited July 2008
    Just save some $$, buy a "good" amp kit. Then take your time and install the kit correctly, leaving the extra wire for when you get your own stuff...
    Mike Bobelak
    Heartland Regional Manager
    Polk Audio
  • bigaudiofanatic
    edited July 2008
    Ya I want to get a stinger kit.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2008
    Dont use speaker wire to power your amps. Its not designed to handle that much current and besides, its way too small. Walmart has 8 gauge wiring kits for like $20. No excuse not to use one.
  • Kinetic
    Kinetic Posts: 437
    edited July 2008
    I dont get it, you already told us that crutchfield are the real experts..
    so?
    http://www.polkaudio.com/forums/showthread.php?t=69894
    Z
    /////Alpine CDA-9887 HU
    /////Alpine KTX-1000EQ
    /////Alpine PDX-4.150
    /////Alpine PDX-1.1000
    Polk Audio SR 6500
    Polk Audio SR 124 DVC
    KnuKonceptz MKS Kable
    G35
    /////Alpine SPX 17PRO
    /////Alpine SWX 1243D
