Harmony One Volume
Early B.
Early B. Posts: 7,900
edited July 2008 in Electronics
I recently added my preamp (Marsh P2000) to the Harmony lineup. The problem is -- the Harmony volume steps are too high. If I press the volume once, it changes the volume by several decibels. However, the preamp's remote works fine. Right now I'm using both remotes. Is there a fix for this?
Another problem is that the sources don't correlate directly. For instance, when I want to listen to music and I use the Harmony, the Marsh will stop at "Tuner" or "Video" instead of "CD." The Marsh preamp is in the Harmony database, so I'm assuming it's coded correctly. Will hard coding the buttons fix these issues?
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • tcrossma
    tcrossma Posts: 1,301
    edited July 2008
    I have the same volume issue with my Harmony 890 and my Adcom 750 preamp. In the "troubleshooting" section of that device you can say that the "device is responding to some commands too many times" and set that setting lower, which helped me a bit. It's still not perfect for me though, and I can't get the fine adjustment I'd like.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Early B.
    edited July 2008
    tcrossma wrote: »
    Thanks!
    This trick worked for my volume adjustment (I set it to zero), but the remote is still having trouble with input selection. It's a minor annoyance, though. I have to use my preamp for HT (no HT pass through feature), and I have to manually adjust the volume anyway, so I can also adjust the input manually, as well.
  • avguytx
    avguytx Posts: 1,628
    edited July 2008
    I have the same problem with my Carver CT-17's volume with the Harmony, too. May have to try that sometime.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
