Sub Request
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited August 2008 in Speakers
Okay I have helped my neighbor get a great Reciverhttp://www.polkaudio.com/forums/showthread.php?t=58973 now it is time to takle the lack of bass. The room is huge the demantions are 24 feet high 24 feet wide and about 14 feet long. So lets hear some suggestions shell we.
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • McLoki
    McLoki Posts: 5,231
    edited July 2008
    How large (physically) is he willing to go and how much is he willing to spend? Also pics of the room would be helpful...
  • bigaudiofanatic
    edited July 2008
    Dont know and probably up to 1k MAYBE PICKS COMMING
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • McLoki
    McLoki Posts: 5,231
    edited July 2008
    8,000 cubic feet of air space (not including any ajoining rooms that may not be able to be closed off - we need to know about those also) is a HUGE space.
    You will get decent bass for 1k, but you may have to spend a little more to actually pressurize that much air. Not saying it won't be well worth the upgrade or money spent, but it will be difficult to pull off with that budget unless DIY is a possibility. Also WAF is probably out the window as small subs able to do the job will be expensive and you will need lots of them.
    An IB (Infinite Baffle) setup may work for you depending on the room and what it connects to....
  • bigaudiofanatic
    edited July 2008
    well there is a hall way conceting into this room all the way to the right plust right by that opening there is the antrance to the dinning room than on the left you have the opening to the kitcken than another opening right next to were the guest bed rooms ar that is like a mini hallway
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Face
    Face Posts: 14,340
    edited July 2008
  • bigaudiofanatic
    edited July 2008
    http://www.crutchfield.com/App/Product/Item/Main.aspx?search=714rt12db&i=714RT12DB
    http://www.crutchfield.com/App/Product/Item/Main.aspx?search=2321000rc&i=2321000RC
    These were recomended by crutchfield after I explained what was in the room and such.
    The su they have now is a Klipsch SW8-II
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Face
    Face Posts: 14,340
    edited July 2008
    The Velo SPL line sounds fantastic, but I'm not sure if it'll fill that room.
  • McLoki
    McLoki Posts: 5,231
    edited July 2008
    That may be the best crutchfield can do for you from what they sell, but I would not consider either of those choices for that room. (8,000ft3 not including 3 connecting rooms and a hallway controlled by a 10" sub - give me a break)
    I think eD (linked to above) or Epik (castle or tower) will be your best bets in a new sub - preferrably a pair of them.
    I have about 12-13k ft3 and with 2-12"subs still wish I had more. (larger subs or a smaller room IS in my future though.)
    Good luck with your search.
    Michael
  • bigaudiofanatic
    edited July 2008
    Thats one thing I love about crutchfield if it's not the right thing you can always send it back.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2008
    SVS PB12/PLus 2 on sale.
  • JDOGG
    JDOGG Posts: 433
    edited July 2008
    He can snag up SlowCars Epik Conquest for $1200.
    Panasonic VIERA 46" 1080p plasma
    Onkyo TX-SR805
    Klipsch RF-7(bi-amped)
    Klipsch RF-25
    Xbox 360 with HD DVD
    Playstation 3
    Cobalt Cable
  • McLoki
    McLoki Posts: 5,231
    edited July 2008
    True, but would also have to get it from Texas to New Jersey. If it was $1200 delivered, I would have purchased it already.... :)
  • BlueFox
    BlueFox Posts: 15,250
    edited July 2008
    And they pay for the return shipping. Every order comes with UPS return labels to slap on the box, and away it goes. UPS will even come to your house and pick it up.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited July 2008
    A pair of Knights or a pair of MFW 15s is the way to go...about the same price and performance.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • curved
    curved Posts: 664
    edited July 2008
    I love my Snell, although I don't think it's big enough to cover that room.
    I would consider getting 2 Polk DSW Pro 500's
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • bigaudiofanatic
    edited August 2008
    So the neighbor is back so we are on the back porch talking about stuff and i bring up i did some sub looking. He explains that his wife dosent like "normal bass" it to loud she says. But he did say well why dont you ask the guys that you asked about the sub. What would they recommend for the same room speaker wise. So lets hear some suggestions. O and if you are wondering what receiver it is a Onkyo TSXR805. With all zones being used.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Sherardp
    edited August 2008
    LSi15s, RTi12s depending on the route he wants to take. A nice amp to boot.
  • McLoki
    McLoki Posts: 5,231
    edited August 2008
    I thought this was the neighboor that had klipsch speakers. (if not, sorry - may be mistaking threads here)
    If so - maybe that is more the direction he should look. If large speakers do not scare him away and he is willing to give Polk a try - I would say SDA 1.2's or 2.3's.
  • bigaudiofanatic
    edited August 2008
    yes it is the same neighbor that has klipsch belle's and DON DON DON bose for rears. Klipsch center and sub. Open to suggestions he does agree that his low are not there like my cars are or even his outdoor speakers. Now that i sort of have him hooked on polk he is courious what we recommend. LOL we have him hooked lets real him in.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • ViperZ
    ViperZ Posts: 2,046
    edited August 2008
    Velodyne DD-15 or HGS-15
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • curved
    curved Posts: 664
    edited August 2008
    Does he want a 2 channel setup or HT? What's his budget look like?
    If he goes with the LSi's, I would highly recommend an amp to power them. If he doesn't want to spend that much, the RTi line is very reasonably priced and doesn't need as much power as the LSi line.
    Pre - Nak CA-5
    BR - LG BD390
  • bigaudiofanatic
    edited August 2008
    Hey curved if I could give you on piece of advice READ THE POSTS Its a HT don't kinow his budget neither does he HE IS JUST CURIOUS WHAT IS RECOMMENDED
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited August 2008
    Bump
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
