DAC builders/modders.I need help/data.
fbm211
fbm211 Posts: 1,488
edited July 2008 in DIY, Mods & Tweaks
I want to upgrade/replace the opamp in my DAC from a NE5532 to a AD825 type 2 Dual AD825.Kyle at audio reference mods wants 175.00 to do it.The opamp is 38.50 (John Hillig/Musical design thinks thats 50.00 too much.)Maybe with some info and help from polkie modders I can do it myself and save some $$$ to spend on other upgrades John can do.Like replace all the power supply caps,Pertinent diods to custom RAM rectifiers, better input/output connectors and maybe a superclock upgrade too.Can anyone here point me to some how to reference guides or books???? Thanks.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • Systems
    Systems Posts: 14,873
    edited July 2008
    What DAC are you modding and do you have a schematic?
    I think the AD825 is only available in surface mount SOIC package,is the 5532 SMT aswell or a standard DIP.Some sort of specialized adaptor board will be needed to get two 825's into the DIP socket.
    Testing
    Testing
    Testing
  • fbm211
    fbm211 Posts: 1,488
    edited July 2008
    Adcom GDA-600.Audio reference mods states the AD825 replaces the NE5532. http://www.referenceaudiomods.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=RAM&Category_Code=OPAMPS
  • Systems
    edited July 2008
    fbm211 wrote: »
    Ah yes that is what I meant,they have designed an adaptor PC board that will allow the 2 SOIC 825's to fit in the DIP foot print of the original 5532.You are paying for this very special board and it is a necessity if you want to use the AD 825's.
    Testing
    Testing
    Testing
  • ben62670
    ben62670 Posts: 15,969
    edited July 2008
    Those boards are very reasonably priced.
    Ben
    Ben
  • Systems
    edited July 2008
    ben62670 wrote: »
    Ben
    $38 is not bad considering its specialized nature and it comes with 2 premium op amps already installed.
    Edit: however after re reading the first post an extra $135 to install it is insane.If you can solder and desolder it should be a simple mod to do.
    Testing
    Testing
    Testing
  • fbm211
    fbm211 Posts: 1,488
    edited July 2008
    Well then its time to order that desoldering iron from PE.Might as well find out what caps I need to get for the power supply and change them too.I think Ill go with black gate.And rubycon ZG/ZLG if some of the blackgates are no longer available.
  • Systems
    edited July 2008
    Get yourself a good soldering staion like the Weller WTCPT and a solder pump (sucker) and you will be well equipt for the job.
    I use the Soldapullt model DS017 pump(see link)
    http://www.hmcelectronics.com/cgi-bin/scripts/product/2920-0019/
    Another good and economical choice for upgrading the power supply decoupling caps is the Panasonic FC series.
    Testing
    Testing
    Testing
  • fbm211
    fbm211 Posts: 1,488
    edited July 2008
    What about this tool for desoldering.And do I need wicks,heat sinks scrapers etc.Im new to this electronic modding thing. http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=370-325
  • Systems
    edited July 2008
    fbm211 wrote: »
    Yes that would be perfect, and yes you should also have a roll of wick and a solder pick.
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    edited July 2008
    For larger joints, I use a desoldering bulb, smaller joints, a desoldering braid. I usually keep a clipped off lead from a mills resistor around while using the bulb, they clog every so often, and the lead is the perfect size to clear the hole.
    heiney9 Posts: 25,396
    edited July 2008
    I'll be watching this thread so be sure to update. I have a 600 as well and I already really like the way it sounds, so if this upgrade can be done fairly easily and it's worthwhile I may try it.
  • sucks2beme
    sucks2beme Posts: 5,681
    edited July 2008
    Check the power supply diodes, and if they aren't FRED(fast recovery diodes)
    replace them with FREDs with the same ratings.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2008
    Waiting on parts.(opamp)And a digital camera to post several pics of the mod in stages.Thanks guys.Im going to call adcom and see if I can get a schematic.That would help a-lot for ordering caps and diodes.
