Off the wall...or on it
jimclass
jimclass Posts: 65
edited July 2008 in Vintage Speakers
I have a friend who insists if I bring my SDA 2As away from the back wall I will gain a greater sense of depth in the soundstage, making it more 3-dimensional. The manual is very specific about keeping them close to the back wall. But can anyone explain why? Also, have you experimented with wall distance and have advice to offer? I have mine about 5 inches off the back wall and they have great stereo enhancement, sounding well to the right and left of the speakers, sometimes the sound seems it is beside me, sometimes like it is floating above the back wall...but not going "back in space" behind the speakers, which is the 3D sound I am speaking of. Anybody?
Post edited by jimclass on
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited July 2008
    I think he is write about taking the away from the wall but I could be wrong. It sounds like it would make sense to allow audio to reverberate off the wall.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • SolidSqual
    SolidSqual Posts: 5,218
    edited July 2008
    http://polksda.com/manuals.shtml
    SDAs are not your average speaker . . . they seem to be best placed close to the wall unless your bass is excessive.
  • Rivrrat
    Rivrrat Posts: 2,101
    edited July 2008
    Move them around a bit and decide what you like.
    I gave up on listening to other peoples advice on how to listen to my equipment, and do what I think sounds best.
    My equipment sig felt inadequate and deleted itself.
  • ben62670
    ben62670 Posts: 15,969
    edited July 2008
    Mine are 8-10" off the wall. They don't sound right any further. Do not toe them in. I sight across one speaker to the other to make sure they are straight.
    Ben
    Ben
    heiney9 Posts: 25,498
    edited July 2008
    Rivrrat wrote: »
    That is true in many cases, but the SDA's need to be set up a specific way to get the most out of them. There are certain guidelines to follow or they won't reach their full potential.
    Close to the wall
    No toe in
    Minimum 5 feet apart; try to keep the equilateral triangle in play.
    Atleast 3 feet distance on either side between the side walls.
    None of this means much unless the cable is in place.
