SDA CRS + Interconnect Cable
rayslifecycle
rayslifecycle Posts: 511
edited February 2013 in Vintage Speakers
I want to fabricate an interconnect cable for my SDA_CRS which has a blade in blade socket.........
so i think the pdf in this thread:
http://www.polkaudio.com/forums/showthread.php?t=55888
which is labelled SDA CRS + 1986 Sch.pdf is the correct schematic.
I am very green and this is probably a stupid question but here it is:
Does each wire connect to the same width socket blade or does the wide blade of one end go into the narrow blade at the other end?
I normally would assume that a wire would connect the terminals of the same width - but I wanted to make sure......
Post edited by rayslifecycle on
  • zingo
    zingo Posts: 11,258
    edited July 2008
    Wide goes to wide and narrow goes to narrow so you are correct. Any switching of signal is done in the x-over. I would just use standard speaker wire for the cable, and then here are the connectors:
    http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=7503200&DESC=&SEARCH=&MPN=
  • rayslifecycle
    edited July 2008
    Thanks for the info zingo - I am going to be comparing the SDA_CRS+ to the Monitor 10s this weekend before deciding which speakers I want to make modifications to first.
  • zingo
    zingo Posts: 11,258
    edited July 2008
    I modded my CRS+ with new x-over components, as well as altering the x-over to accept the SL3000 which was switched to the RDO198. After 200 hours or break-in on all the parts, they are FANTASTIC sounding speakers. Very warm and detailed, yet they don't over power and can be used in almost any room. I also built a custom Pin-Blade SDA cable to match my speaker cables in look, quality, and sound.
    F1nut Posts: 51,997
    edited July 2008
    Polk sells them, $35.00 a pop.
  • ESavinon
    ESavinon Posts: 3,067
    edited July 2008
    Typewriter fan?
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • rayslifecycle
    edited July 2008
    Not since Fadela stormed in here and threw my typrwiter out the window......
  • ESavinon
    edited July 2008
    William s. burroughs fan i see.
    Very Good movie but the book is better.
  • rayslifecycle
    edited July 2008
    I ordered an interconnect cable from my local store, Grafitti Audio Video, here in Bethesda........can't wait to try it out. It is important to support local business - especially if they are really good to do business with.
    Instead I tried hooking my amp up to the home network and started trying out internet radio. Some of the stations broadcast in very good quality.
    There is a review posted here:
    http://www.polkaudio.com/forums/showthread.php?t=70594
    Thanks for the help everyone.
  • zingo
    zingo Posts: 11,258
    edited July 2008
    He he...I forgot that you had the room with lots of speakers in a small area. But to each his own! Good luck with the same and thanks for supporting small businesses.
  • rayslifecycle
    edited August 2008
    Got the interconnect cable yesterday. When I hooked it up this morning - my SDA-CRS+ speakers were twice as loud and the "S" sound coming from peoples voices became quite obnoxious.
    I am guessing that only one woofer is powered without the interconnect and the sound I was hearing from the more quiet woofer was the result of it being a passive radiator?
    Re-running the Audessy EQ tonight .........hopefully this will tame the wild little beasts.
  • ben62670
    ben62670 Posts: 15,969
    edited August 2008
    Dual tweeter model? If so try disconnecting the outer tweeters. This will clean the funky sound you described. The treble will be a little lower, but there is an easy fix if you like the new sound.
    Ben
    Ben
  • rayslifecycle
    edited August 2008
    Single tweeter model - but it was definitely different after plugging in the interconnect. I will probably make these the first speakers I upgrade with caps, resistors and tweeters after my friend in Buffalo delivers the 7Bs.
    Ray
  • dengood1
    dengood1 Posts: 9
    I know this is an old post but did Audessy eq tame the wild little beasts? I'm experiencing the same strong treble and thought about doing the same thing.
