Another pair of GFA-565's go under the gun
ben62670
ben62670 Posts: 15,969
edited August 2008 in DIY, Mods & Tweaks
Well I am working on a pair of GFA-565's for a Polkie. This one is the worst case I have seen yet. The Caps are so bad that a couple of the legs have disintegrated. Well I have the input boards removed, and the gun hot. Time to get busy.
Ben
Ben
Post edited by ben62670 on
    heiney9 Posts: 25,405
    edited July 2008
    ben62670 wrote: »
    Ben
    Dammit!!! We want pics.................we want pics.
    Hey Ben we need pics :D
  • george daniel
    george daniel Posts: 12,096
    edited July 2008
    Those 565's have gotta belong to someone who lives west of Atlanta. :)
  • ben62670
    edited July 2008
    OK, and yep yep yep.
    Ben
  • ben62670
    edited July 2008
    OK where you see bad cap that is where the cap was. Notice the stains. Where you see good cap someone had replaced them, and not the others:confused: Where you see Servo IC that is where the DC offset opamp is located. It is too close to the nasty cap so I just replace the unit anyways because they are cheap, and this is what regulates DC offset. Good caps will be replaced too, and I had also removed the bias trim pot for the ultra sonic cleaning process. They don't like to get wet;)
    Ben
  • steveinaz
    steveinaz Posts: 19,545
    edited July 2008
    heiney9 wrote: »
    That's right. No pics, then it didn't happen.
    Oh...sorry man , you got pics. I guess it DID happen. :D
  • Systems
    Systems Posts: 14,873
    edited July 2008
    Are these the models that had the wrong voltage caps installed?
    Since it uses a DC servo I guess they were able to eliminate an input coupling cap?
    Testing
    Testing
    Testing
  • ben62670
    edited July 2008
    GV#27 wrote: »
    What happened with these amps is unfortunately Elna had a bad run on caps that failed over time and leaked all over the input boards. I think that you are correct that these are direct coupled amps;)
    Ben
  • ben62670
    edited July 2008
    Cleaned, and ready for re-population. The US cleaner, and simple green goes a long way;) Compare to earlier pic of board:eek:
    Ben
  • ben62670
    edited July 2008
    ReCapped, and trim pot reinstalled. I need the OpAmp though. I wish you could just run to the store for these.
    Ben
  • danger boy
    danger boy Posts: 15,722
    edited July 2008
    what would happen if you replaced the wires inside with silver wire?
    Just curious...
    PolkFest 2012, who's going>?
  • ben62670
    edited July 2008
    One mod some guys do is to replace the bars with wire. I have not tried it yet, but there is supposed to be a decent difference. Its kinda like doing away with the jumpers, and using wire on bi ampable speakers.
    Ben
    Ben
  • fbm211
    fbm211 Posts: 1,488
    edited July 2008
    Could you show us 565 owners where to solder on 12uF caps onto the main caps for that other mod you suggested.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited July 2008
    Where do the tubes go?
  • ben62670
    edited July 2008
    fbm211 wrote: »
    Non polars right across the top of the main caps;)
    Ben
  • ben62670
    edited July 2008
    RuSsMaN wrote: »
    In my pre:)
    Ben
  • hoosier21
    hoosier21 Posts: 4,415
    edited July 2008
    man I leave for vacation and my amps are ripped open, cleaned and repaired, good deal.
    Ben, let me know what op amps to get and I will get them going.
    Thanks for the work, looks great so far.
    Russ
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • ben62670
    edited July 2008
    I'll get that list to you soon.
    Its looking pretty good. This was the bad one;)
    Ben
    Ben
  • ben62670
    edited August 2008
    Well I finished the bad one. Took a little hunting. There was an open resistor on the board(r135 83r 1/4w fusible). It was only pushing, and not pulling. It was very distorted. Now it is beautiful, and DC offset is <10mv :) This is great news. These thing are a **** to fix!
    Ben
    Ben
  • ben62670
    edited August 2008
    Here goes number two. I have it all apart. This one is a mess too. Looks like they let a kid do the soldering on this one. I can't believe they went through the trouble of replacing the caps, but did not clean it. This one is just under 1vdc DC offset. They stuck a big ugly 1/2 watt resistor in the signal path where a 1/4w resistor is supposed to go. Time for the board to take a bath in some simple green in the ultra sonic cleaner.
    Ben
    Ben
  • ben62670
    edited August 2008
    Second one done. All new caps like the other. DC offset less than 4mv right out the bath:D I am very pleased. These things are at new specs, and good for a long time to come. I don't want to give these back. They run better than mine:mad:
    HEY RUSS I'M DONE!
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited August 2008
    Great job Ben.
    engtaz
    engtaz
  • zingo
    zingo Posts: 11,258
    edited August 2008
    I too like your work Ben.
  • ben62670
    edited August 2008
    Thanks Guys. I am very pleased with the outcome. I am going to have to do mine. I have one that isn't behaving very nicely. One gets a DC offset that swings up to 8vdc:eek: Not good for speakers at all:(
    Ben
    Ben
  • ben62670
    edited August 2008
    Well I finally got tired of looking at my GFA-565's. It was their turn today:) Both are running to the same specs as Russ's:D I am very pleased:D:D. I can now run 4 565's, and a 585 on my big speakers. It'll be interesting:D:D:D
    Ben
    Ben
  • ben62670
    edited August 2008
    Ya know what I like most about the amps I have repaired. Most of them you can tell someone else was in there trying to fix them. Even funnier is the repair shops that have put their name on the shoddy work they have performed:p
    Ben
