stacked LSi9s - part 2
SlowcarIX
SlowcarIX Posts: 887
edited July 2008 in Speakers
didnt go too well stacking 6 high...http://www.polkaudio.com/forums/showthread.php?t=69504
how about 4 on the sides
this guy had good results with stacking 4: http://forum.ascendacoustics.com/showpost.php?p=28182&postcount=45
using these...http://www.ascendacoustics.com/pages/products/speakers/SRM1/srm1.html
worth trying?
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Post edited by SlowcarIX on
  • hockeyboy
    hockeyboy Posts: 1,428
    edited July 2008
    No. Why not let the experts who have sound labs build speaker configs for us?
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • ben62670
    ben62670 Posts: 15,969
    edited July 2008
    The tweeters will have phase, and lobing issues.
    Ben
    Ben
  • Shicks18
    Shicks18 Posts: 397
    edited July 2008
    kinda looks like SDA 1.2TLs minus the woofer at the bottom
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Front Amp: Parasound HCA-1000A
    Center Amp: Marantz MA500
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
    Games: Xbox360 and PS3
    heiney9 Posts: 25,630
    edited July 2008
    ben62670 wrote: »
    Ben
    BIG TIME.
    Stacking is rarely a good idea unless you don't care at all about proper phase, time coherence, soundstaging and overall good sound with proper dispersion.
    But hey if it floats your boat, rock on.
    treitz3 Posts: 20,275
    edited July 2008
    Why don't you just get a pair of SDA 1.2TL's?
  • Frank840
    Frank840 Posts: 262
    edited July 2008
    hey try it i take donations if you dont like it :rolleyes::p
    - This your Bush?
    Pioneer Elite Sc-25
    Polk Lsic,15's,9's, PSW1000
  • devani
    devani Posts: 1,497
    edited July 2008
    so you won't mind buying 8 of LSi9's stacked but with that money you can buy something better
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • obieone
    obieone Posts: 5,077
    edited July 2008
    devani wrote: »
    Seriously! 8 x $900= $7,200. That'll go a LONG ways on A-Gon!:eek:
  • Ron Temple
    Ron Temple Posts: 3,212
    edited July 2008
    Abner, I'm with Tom. Maybe, the Sierras work fine in that config, but I say get some 1.2TLs and call it a day. Once you jump in, it will be awhile before you get over them.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • fossy
    fossy Posts: 1,378
    edited July 2008
    $7200 bucks can buy a pair or 2 of really nice speaks
    but at the same time, I say go for it , see what happens
    you always see lsi9's on agon for 5-6 hundred -- goin used you could do it for half the price
  • Shicks18
    Shicks18 Posts: 397
    edited July 2008
    For $7200 get 4 pairs of 1.2tl's !!!! 4 x $1800 = $7200
    haha, or get 3 pairs and with the remaining $1800 get 3 kick **** 2 channel amps!
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • Hawkeye
    Hawkeye Posts: 1,313
    edited July 2008
    I thought I saw a line array @ AV123 or something like that for less change. If you want a line array, buy one that has been designed that way. But, it's your money so go for it!
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • SlowcarIX
    edited July 2008
    ben62670 wrote: »
    Ben
    heres an explaination by David Fabrikant - www.ascendacoustics.com
    http://forum.ascendacoustics.com/showpost.php?p=28482&postcount=110
    "Like all things audio, every design is a compromise at some point. I read that *post* over at Hsu's and it is what I like to call a half-truth. Due to a general lack of knowledge, lobing has gotten a bad rap - seems it is always associated with being a bad thing which is only 50% correct. Vertical lobing is a good thing, it is what makes MTM speakers so popular and so successful in the marketplace. A large vertical lobe decreases vertical dispersion which diminishes the effect of ceiling and floor bounce, reducing reverberation which increases intelligibility. (see Ron's un-EQ'd measurements and notice the reduction in the dip at 180Hz as compared to the single speaker measurements, this is floor bounce) Intelligibility of a loudspeaker can be thought of as a ratio between the direct sound of a loudspeaker and the background noise in a room. The less background noise, the more clarity. Same general principle as acoustically treating a room.
    Ron's setup should be considered a vertical line array, quite common in the loudspeaker industry and even more common in sound reinforcement applications. The taller the array, the more limited the vertical dispersion becomes. Provided the listener is within the lobe (listening height is not above or below the column), vertical lobing is beneficial. Vertical line arrays also project sound a bit differently than a conventional loudspeaker, with the rate of SPL decrease with reference to distance being about half that of a conventional loudspeaker. For example, at 2 meters away with the same voltage level, the line array will sound louder and cleaner.
    In addition to the advantages as described above, there will be major improvements with regards to distortion, headroom capability and dynamics.
    Are there disadvantages? Certainly -- if not seated within the vertical lobe clarity will be diminished rather than enhanced. Horizontal dispersion is slightly reduced but this would only become a problem if seated at an off-axis angle of 20 degrees or greater from either stack. In addition, this type of setup is not recommended for extreme near field listening or extreme far field listening where there can be frequency response changes.
    Due to the unique phase integration of the woofer and tweeter, which closely emulates single point source radiation up to about 20-25 degrees, the Sierra-1 works exceptionally well in this particular application, far better than our other products.
    Ron's requirements were unique... He loves the sound of the Sierra-1 but desired more. His primary requirement was that he wanted the ability for extremely high sound pressure levels while maintaining clarity (a serious problem for many rooms as room effects before more pronounced at higher levels). In addition, Ron seldom listens off-axis and never in the near field. He has acoustic room treatments on the front, rear and side walls but he has a wooden floor and I don't believe the ceiling is treated, thus limiting vertical dispersion became high priority. Considering all of these factors and after many discussions about the pro's and con's, only then did I begin running various tests of the stack. To my surprise, and as I mentioned before, the stack actually far exceeded my expectations.
    In addition, the type of line array offers benefits over a typical multi-driver line array.
    1. Each woofer is in its own dedicated and damped enclosure. There are no modulation effects between woofers because they do not share the same cabinet volume.
    2. Considering all of the individual enclosures and the fact that each of these enclosures are laminated bamboo, cabinet resonance and energy loss will be dramatically less than a typical floor standing line array -- I would wager less cabinet resonance than nearly any floor standing loudspeaker on the market.
    3. There are multiple crossovers being used. A typical line array uses a single crossover for all of the driver elements (each driver being directly connected to the same crossover output). With multiple crossovers; saturation effects, distortion and heat are dramatically reduced due to current being equally distributed between all of the crossovers as opposed to a single crossover network. At extreme listening levels (high current) this becomes a tremendous advantage.
    Some people who read this thread will see this as a gimmick or even a juvenile attempt to sell a lot of loudspeakers. Nothing could be further from the truth. Ron's solution is what defines acoustic engineering, designing a sound system that meets or exceeds the challenges set forth... With that in mind and from the various comments I have received from those lucky enough to experience it in person, expectations and requirements have been met"
    anyways, no more of this speaker stacking business for me...:o
    my 7.(1x4) HT setup
    Buttkicker
  • Face
    Face Posts: 14,340
    edited July 2008
  • unc2701
    unc2701 Posts: 3,587
    edited July 2008
    Heh. Hey, SlowcarIX, you can build those McIntosh XRT's
    You need 12 of these:
    Subwoofers
    80 of these:
    Tweeters
    and 128 of these:
    Mids
    Crossover & cabinet and you're done! Only $9528
    Backburner:Krell KAV-300i
  • SlowcarIX
    edited July 2008
    lol, thats awesome!!
    $8575.60 for all the drivers alone for L/R...:D
    how did u estimate the price for the cabinet and x'over?
    earlier on, i was thinking of getting a bunch of these and gutting them for drivers...:o
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited July 2008
    Face wrote: »
    :eek:
    or one pair of these from a-gon...:D
    my 7.(1x4) HT setup
    Buttkicker
  • zingo
    zingo Posts: 11,258
    edited July 2008
    I would go for the Infinity RS, or just build a pair of these; directions are parts list included:
