Help to fix boomy bass
Hi guys,
I'm running an RTi setup (10s for fronts, 6s for rear surrounds, FXi3s for surrounds and CSi5 for center) powered by an emotiva LPA-1 amp with Sony STR-DG1000 as pre-pro. Combo sounds great - only one problem. My room (see pic) requires that one of my RTi10s is in the corner. Both of the RTi10s are only ~2 feet from the wall.
What I have found is that my RTi10s (in this arrangement) create boomy bass that overpowers everything (the boomy bass is in the 60-80Hz region). I've run the auto-EQ correction in my receiver which has improved things but I feel that the correction takes away too much bass and seems to make the midrange thin out as well.
My ideas so far:
1) Put some sort of treatment in the corner of the room where the RTi10 is located (not sure what treatment or how to do it)
2) Stuff the powerports on the RTi10s.
3) Raise the crossover on the RTi10s (don't really want to do this -why pay for a full range speaker only to cut it short).
I'd appreciate anyone's input on any of these ideas or any other solutions to overpowering bass.
My ideas so far:
Post edited by nm4710 on
Try stuffing the power ports. That should help a bit. Another suggestion, attenuate the bass a bit without any auto EQ feature running at all and see hoe that improves things.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
nm: Had the same prob - but it really wasn't location of the RTi10's.(they're nowhere's near a wall).
I used to have my sub across the room -I moved my sub between the speakers.BOOM GONE. If you can squeeze it in, give it a try. I sometimes wonder if all those layouts with sub away and in corner are for boom lovers...
Assuming that's a no go: I think your first idea, is the simplest and will likely have an impact. Personally I'd add some wall hanging behind the 10's to cancel reflective noise from speaker's rears - something heavy, wooly, weavy and thick would probably do a darn good job (cheaper and better looking than 'treatments' if not quite so effective).
ByetheBye: I'm a newbie, and tastes vary but you should probably also try varying the 10's crossover point. Although I have mine RTi10's set to 60. Crossover on My NAD SACD player is set to 80 (and it still sounds loverly). Although you COULD set 10's as large, sending the lowest stuff to the sub really seems to allow the speakers to focus better the mid and upper range (also decreasing the boom effect).
Again, 99% of the gang here has far more expertise, but this has been my experience with the 10's. YMMVLR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
Plug the ports.
Set them to small, or cutoff at 80hz if your receiver has a crossover. -
Towers in tight quarters sometimes benefit from from a solid plat form below, and raising them a bit. Maybe thick concrete pavers? Do you have slab construction or a wood sub-floor?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thanks for the advice guys.
Xandra - I find the speakers are actually that boomy even with the sub off. I will try to find something to hang behind/around them.
Phuz - My speakers are set to small; unfortunately I don't know the crossover frequency (it's determined by the receiver).
Steve - I believe I have slab construction (highrise apt building).
I'll try plugging the ports and seeing if that helps. -
My ideas so far:
The one idea you failed to mention is the one that will help the most - add half a dozen (or more) corner bass traps in the room.
--EthanRealTraps -
Hey Ethan, nice to see you on this forum. Your expertise will be welcomed. I've still got my eye on your diffusion panels, still working on the wife!
I'd go with the bass traps...
I'd quit listening to rap.;):D"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Pull those speakers away from the wall. Move them a foot or two forward and toe them in slightly. Problem solved.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
