Help to fix boomy bass
nm4710
nm4710 Posts: 97
edited July 2008 in Speakers
Hi guys,
I'm running an RTi setup (10s for fronts, 6s for rear surrounds, FXi3s for surrounds and CSi5 for center) powered by an emotiva LPA-1 amp with Sony STR-DG1000 as pre-pro. Combo sounds great - only one problem. My room (see pic) requires that one of my RTi10s is in the corner. Both of the RTi10s are only ~2 feet from the wall.
What I have found is that my RTi10s (in this arrangement) create boomy bass that overpowers everything (the boomy bass is in the 60-80Hz region). I've run the auto-EQ correction in my receiver which has improved things but I feel that the correction takes away too much bass and seems to make the midrange thin out as well.
My ideas so far:
1) Put some sort of treatment in the corner of the room where the RTi10 is located (not sure what treatment or how to do it)
2) Stuff the powerports on the RTi10s.
3) Raise the crossover on the RTi10s (don't really want to do this -why pay for a full range speaker only to cut it short).
I'd appreciate anyone's input on any of these ideas or any other solutions to overpowering bass.
Post edited by nm4710 on
    treitz3 Posts: 20,007
    edited July 2008
    Try stuffing the power ports. That should help a bit. Another suggestion, attenuate the bass a bit without any auto EQ feature running at all and see hoe that improves things.
  • xandra
    xandra Posts: 291
    edited July 2008
    nm: Had the same prob - but it really wasn't location of the RTi10's.(they're nowhere's near a wall).
    I used to have my sub across the room -I moved my sub between the speakers.BOOM GONE. If you can squeeze it in, give it a try. I sometimes wonder if all those layouts with sub away and in corner are for boom lovers...
    Assuming that's a no go: I think your first idea, is the simplest and will likely have an impact. Personally I'd add some wall hanging behind the 10's to cancel reflective noise from speaker's rears - something heavy, wooly, weavy and thick would probably do a darn good job (cheaper and better looking than 'treatments' if not quite so effective).
    ByetheBye: I'm a newbie, and tastes vary but you should probably also try varying the 10's crossover point. Although I have mine RTi10's set to 60. Crossover on My NAD SACD player is set to 80 (and it still sounds loverly). Although you COULD set 10's as large, sending the lowest stuff to the sub really seems to allow the speakers to focus better the mid and upper range (also decreasing the boom effect).
    Again, 99% of the gang here has far more expertise, but this has been my experience with the 10's. YMMV
    LR Setup:
    Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
    Onkyo 705 & Denon 3808ci Receiver, Onk 875
    Parasound 2250 Amp
    Sony 26" KDL series Bravia LCD
    Panny DMR-EH75 Recorder
    Panny DVD-F87 (5 disk DVD player)
    NAD T585 (DVD/SACD)
    Yamaha DVD-C961 (5 disk SACD/DVD)
    SciAnt Explorer 8500HD Cable Box
    Orig & 5Gen iPods, , Wii
    Plans/Fantasies:
    • 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
  • phuz
    phuz Posts: 2,372
    edited July 2008
    Plug the ports.
    Set them to small, or cutoff at 80hz if your receiver has a crossover.
  • steveinaz
    steveinaz Posts: 19,545
    edited July 2008
    Towers in tight quarters sometimes benefit from from a solid plat form below, and raising them a bit. Maybe thick concrete pavers? Do you have slab construction or a wood sub-floor?
  • nm4710
    nm4710 Posts: 97
    edited July 2008
    Thanks for the advice guys.
    Xandra - I find the speakers are actually that boomy even with the sub off. I will try to find something to hang behind/around them.
    Phuz - My speakers are set to small; unfortunately I don't know the crossover frequency (it's determined by the receiver).
    Steve - I believe I have slab construction (highrise apt building).
    I'll try plugging the ports and seeing if that helps.
  • Ethan Winer
    Ethan Winer Posts: 8
    edited July 2008
    nm4710 wrote: »
    My ideas so far:
    The one idea you failed to mention is the one that will help the most - add half a dozen (or more) corner bass traps in the room.
    --Ethan
    RealTraps
  • pearsall001
    pearsall001 Posts: 5,296
    edited July 2008
    Hey Ethan, nice to see you on this forum. Your expertise will be welcomed. I've still got my eye on your diffusion panels, still working on the wife!
  • amulford
    amulford Posts: 5,020
    edited July 2008
    I'd go with the bass traps...
  • ND13
    ND13 Posts: 7,601
    edited July 2008
    I'd quit listening to rap.;):D
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • Early B.
    Early B. Posts: 7,900
    edited July 2008
    Pull those speakers away from the wall. Move them a foot or two forward and toe them in slightly. Problem solved.
    "God grooves with tubes."
