Spades or Banana plugs for Speaker Binding posts?
hamzahsh
hamzahsh Posts: 439
I'm interested to use heavy duty gold spades or banana plugs for all of Polks.
I would love to use banana plugs. My question is would they fit into Speaker binding posts or not?
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player)
Post edited by hamzahsh on
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2003
    They will fit as long as they are 4 or 5 way binding posts. They probably are. What models of Polk?
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2003
    Check his sig.
    Cheers,
    Rooster
  • mantis
    mantis Posts: 17,394
    edited May 2003
    The better question will banana plugs fit that receiver........might need pins on one side.I don't know that receiver.Does it have binding posts or spring clips????
    The Polk speakers will take spades or bananas.......
    Dan
  • RuSsMaN
    edited May 2003
    Someone post a back-panel pic, right diddy.
    Cheers,
    Rooster
  • mantis
    edited May 2003
    2nd that
    Dan
  • hamzahsh
    hamzahsh Posts: 439
    edited May 2003
    Thanks for the help everybody!
    mantis, I'm planning to upgrade my receiver to Denon AVR-3803. My Technics SA-DX940 got spring clips and only L/R are binding post.
    If my Polks take banana then I got my answer. Thanks mantis.
    NAD C272 (2-ch Amp)
  • dorokusai
    edited May 2003
    :lol: Thx Russman, I am zoned out I guess. I will ban myself for 30 minutes due to being lame.
    F1nut Posts: 51,774
    edited May 2003
    WAAAAAAAAAAAAAAAAAAAAAAAH
  • mantis
    edited May 2003
    hamzahsh
    cool man,the avr3803 is an excellent choice.
    Dan
  • ezc
    ezc Posts: 426
    edited May 2003
    I use on the speaker end & bananas on the receiver. if this helps!
  • mantis
    edited May 2003
    you use.............on the speaker end?
    Dan
  • Tour2ma
    Tour2ma Posts: 10,177
    edited May 2003
    you know Mantis... "ON"... it's the hottest and latest for terminations. :D
    More later,
    Tour...
    Vox Copuli
