Opinion/Experience
heiney9
heiney9 Posts: 25,630
edited July 2008 in Electronics
Anybody had any expeiences with the Acurus DIA-100 integrated? DIA stands for Direct Input Amplifier as the pre-amplifier is a completely passive stage. 100w into 8 ohms and 150 into 4 ohms.
Talked my bro into buying it to run his Lsi 7's on the computer rig. The Adcom GCA-510 which is the same kind of design (integrated w/ a passive line stage pre-amp section) but just not quite enough balls to run the Lsi's at higher volumes (50w into 8 ohms 80 watts into 4 ohms).
It was an impulse buy and from what I've read it's a nifty little integrated. Now I can get the GCA-510 from him and possibly his Lsi 7's as he bought some Lsi 9's a few hours ago also as an impulse buy.
Just looking for comments about this integrated or Acurus (Mondial) gear in general.
Post edited by heiney9 on
  • jon s
    jon s Posts: 905
    edited July 2008
    How does your brother like the Acurus? I am in the process of buying a DIA-100 myself and am wondering how it sounds and whether it has enough power.
    edited July 2008
    Absolutely loves it. A very very nice unit for not a lot of $$$. That was my 2nd choice for my computer rig. I had a line on one about a year ago for $175 shipped which was an awesome deal.
    The whole idea of a passive line stage pre section appeals to me. It's a fairly large unit. I ended up getting a rare Adcom integrated amp that also uses a passive line stage pre section.
    You won't be disappointed
  • jon s
    jon s Posts: 905
    edited July 2008
    Thanks... I am considering this amp as well as a Nakamichi PA-5 Stasis amp. I was given a PA-5 but I would need to buy a Nakamichi CA-5 preamp to run it (well, I would like to keep the components matched). i can get the DIA-100 $300 shipped to Hawaii ($175 + $125 shipping (it's tuff living in Hawaii)). i want to run it with the Polk RTA-12C which presents a difficult load because of its low impedance. My normal amps run out of current real quick driving this speaker compared to my Model 10s...
    edited July 2008
    jon s wrote: »
    Actually you don't have to run it with a CA-5. I have a CA-5 (which is a killer pre) and I run it with my Adcom. If aesthetics are extremely important then I guess so.
    The PA-5 is a very nice amp. It has very nice "tube like" highs and and a very liquid mid range, but it lacks a bit in the bottom end. It's powerful enough; it's just a bit soft in the lower regions for my taste. I encourage you to get a pre-amp and listen to the PA-5. If you watch CA-5's can be had fairly cheaply. There are a couple on audiogon right now but, IMO, they are a little overpriced.
    I love my CA-5 and it's going to take a lot for me to replace it.
  • jon s
    jon s Posts: 905
    edited July 2008
    looks like we have similar tastes...
  • jon s
    jon s Posts: 905
    edited July 2008
    okay, I bit the bullet and bought the DIA-100, shud be here in about two weeks. See what the amp can really do. Jeez, spent way too much money this summer, $300 on the SDA-1B, $450 on the Monitor 10 (including crossover upgrade and new RDO194s), $650 on the RTA-12Cs (crossover upgrade and new RDO194s again) and the Acurus DIA-100 for $300, I am also bidding on a NIB Nakamichi CA5 pre-amp to match the PA5 Stasis power amp and some other Polk drivers. Blowing about $2,000 this summer so far... ouch!!!
