PASS B1 buffered pre amp.
Systems
In case anyone is interested,Nelson Pass is making plans available for a DIY version of his new B1 buffered(no gain) JFET preamp.http://www.enjoythemusic.com/diy/0708/first_watt_b1_preamplifier.htm
This would be a nice little project for anyone that does not need any gain in their pre but don't like the loss of dynamics that accompany the puerly passive pre approach.
It should be very simple and reasonably inexpensive to build.He will apparently offer the PC boards for sale soon but this can easily be built on some perf or vector boards.And as with other NP designs one can expect it to sound very good.Im currently using another one NP's DIY JFET designs but Im thinking of building this one just for the heck of it.
Testing
Testing
Testing
Testing
Testing
I'll have to look into this, thanks for the heads up."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I wonder how it compares to the bride of zen. Seems a strange design for pass as most of the Aleph amps have very low gain and need a medium-high gain pre to sound their best.
I wonder how it compares to the bride of zen.Seems a strange design for pass as most of the Aleph amps have very low gain and need a medium-high gain pre to sound their best.Testing
Testing
Testing -
yep... made the B1 last night. nice sounding. fills in the upper end, made gainclone sound much smoother and more balanced. will try driving couple other amps with. should be useful protecting my weak sources an 'output opamp removed' modded sb3 and monica2 with no iv stage.
1.did you use a stepped attenuator or pot for the volume control?
2.where did you sourced the jfets from?
BTW welcome to the forum.Testing
Testing
Testing -
post quick pics of it later tonight... really easy to do on perf board. i used 12uf polyprop dayton's i had laying around on output. 4.7uf polypropolene axon (brand like NP uses on output) on the input.
used basic linear power supply. transformer -> rectifier -> 1000uf||1000uf -> 1 ohm -> 1000uf||1000uf -> 1 ohm -> 15000uf like the B1 article ps there on.
used a basic 50k ohmite pot i had laying around, maybe swap a panasonic one in there. eventually get around to ordering another batch of alps blue velvets. can't bring self to put big money into pot since i tinker and go through so many electronics.
oh yeah... can get the jfets, sk170's, from mcm electronics or ampslab. been ordering most of my little jfets from ampslab recently. -
Would this work well teamed with a Welborne ST-70? I have a Dynaco Pat 4 that I can gut out and use as a home for the PASS B1. It would be for a bedroom rig with a pair of fairly efficient Tannoys."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Would this work well teamed with a Welborne ST-70? I have a Dynaco Pat 4 that I can gut out and use as a home for the PASS B1. It would be for a bedroom rig with a pair of fairly efficient Tannoys.Testing
Testing
Testing -
oh yeah... can get the jfets, sk170's, from mcm electronics or ampslab. been ordering most of my little jfets from ampslab recently.Testing
Testing
Testing -
Hi Tim. Monica II is pretty weak, I recall having to turn it up ~ 10db to match my other DACs, so thats what .2v output? Your SB3 sounds like what RWA used to do, they bypass the op-amp with a auricap, running the signal direct from the dac chip.
P.S. Welcome to club polk, theres a fun thread on the Audio Zone gear somewhere on here, might want to check it out.
