PASS B1 buffered pre amp.
Systems
Systems Posts: 14,872
edited July 2008 in DIY, Mods & Tweaks
In case anyone is interested,Nelson Pass is making plans available for a DIY version of his new B1 buffered(no gain) JFET preamp.http://www.enjoythemusic.com/diy/0708/first_watt_b1_preamplifier.htm
This would be a nice little project for anyone that does not need any gain in their pre but don't like the loss of dynamics that accompany the puerly passive pre approach.
It should be very simple and reasonably inexpensive to build.He will apparently offer the PC boards for sale soon but this can easily be built on some perf or vector boards.And as with other NP designs one can expect it to sound very good.Im currently using another one NP's DIY JFET designs but Im thinking of building this one just for the heck of it.
Testing
Testing
Testing
  • Face
    Face Posts: 14,340
    edited July 2008
    I'll have to look into this, thanks for the heads up.
  • Gaara
    Gaara Posts: 2,415
    edited July 2008
    I wonder how it compares to the bride of zen. Seems a strange design for pass as most of the Aleph amps have very low gain and need a medium-high gain pre to sound their best.
  • Systems
    edited July 2008
    Gaara wrote: »
    The fact that it uses jfets as opposed to the MOSFET's used in the BOZ,it should have considerably lower noise and distortion.I have a BOZ and while it sounds good I much prefer the sound of my DIY jfet pre that Nelson outlined in his DIY op-amp article.
    Yeah his First Watt amps (F1-F5)are also a little on the low side as far as gain is concerned(ie.15.5db for the F5) but it will be highly system dependant as to the need of extra gain in the pre.
    Testing
    Testing
    Testing
  • rawsonte
    rawsonte Posts: 2
    edited July 2008
    yep... made the B1 last night. nice sounding. fills in the upper end, made gainclone sound much smoother and more balanced. will try driving couple other amps with. should be useful protecting my weak sources an 'output opamp removed' modded sb3 and monica2 with no iv stage.
  • Systems
    edited July 2008
    rawsonte wrote: »
    Cool ,now its a must for you to post some pics:D,A couple of questions if I may.
    1.did you use a stepped attenuator or pot for the volume control?
    2.where did you sourced the jfets from?
    BTW welcome to the forum.
    Testing
    Testing
    Testing
  • rawsonte
    rawsonte Posts: 2
    edited July 2008
    post quick pics of it later tonight... really easy to do on perf board. i used 12uf polyprop dayton's i had laying around on output. 4.7uf polypropolene axon (brand like NP uses on output) on the input.
    used basic linear power supply. transformer -> rectifier -> 1000uf||1000uf -> 1 ohm -> 1000uf||1000uf -> 1 ohm -> 15000uf like the B1 article ps there on.
    used a basic 50k ohmite pot i had laying around, maybe swap a panasonic one in there. eventually get around to ordering another batch of alps blue velvets. can't bring self to put big money into pot since i tinker and go through so many electronics.
    oh yeah... can get the jfets, sk170's, from mcm electronics or ampslab. been ordering most of my little jfets from ampslab recently.
  • Face
    Face Posts: 14,340
    edited July 2008
    Would this work well teamed with a Welborne ST-70? I have a Dynaco Pat 4 that I can gut out and use as a home for the PASS B1. It would be for a bedroom rig with a pair of fairly efficient Tannoys.
  • Systems
    edited July 2008
    Face wrote: »
    Yeah ,assuming the source is a CD/DVD player with the standard 2volts of output and the Tannoys are atleast 90db ish efficient then it should work just fine.
    Testing
    Testing
    Testing
  • Systems
    edited July 2008
    rawsonte wrote: »
    I have a little Talema toroid that I plan to use with an LM7818 regulator,then duplicate NP,s schematic.I ll see how much PASS wants for the PCB's ,if too pricey I'll use just some perf board.
    I don't know of any supplier in Canada so I ll check with Ampslab.
    Testing
    Testing
    Testing
  • Gaara
    Gaara Posts: 2,415
    edited July 2008
    rawsonte wrote: »
    Hi Tim. Monica II is pretty weak, I recall having to turn it up ~ 10db to match my other DACs, so thats what .2v output? Your SB3 sounds like what RWA used to do, they bypass the op-amp with a auricap, running the signal direct from the dac chip.
    P.S. Welcome to club polk, theres a fun thread on the Audio Zone gear somewhere on here, might want to check it out.
