Integra 9.8 & DTS pop
dholmes
dholmes Posts: 1,136
edited July 2008 in Electronics
Well Ive got that problem with DTS ma audio that suddenly everything goes POP!! I called Integra & its a problem thats been around for a while,they first suggested I send it to a service center but they also said there is a fix & sent me email of what to do.Anyone out there have this problem & fixed it there self? thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • millerman 3732
    millerman 3732 Posts: 1,488
    edited June 2008
    dude, we've talked about this ;)
    http://www.polkaudio.com/forums/showthread.php?t=68821
    Here is the link to the DSP update from AVS.
    http://www.avsforum.com/avs-vb/showthread.php?t=1016297
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • dholmes
    edited June 2008
    Yes I know,I got a email from Integra of what to do .Im not very good with computers & thought someone might let me buy or borrow the update disc.thanks
    billbillw Posts: 8,102
    edited June 2008
    dholmes wrote: »
    I'll check and see if I can dig up the DSP update disc that I burned a few months ago. If I can, I'll drop it in the mail to you.
  • dholmes
    edited June 2008
  • dholmes
    edited June 2008
    Integra emailed me a file that I dont understand it reads 63.148.251.142 Why dont they just send a cd with the firmware up-grade.I get so sick of all this firmware shittt!!
  • millerman 3732
    edited June 2008
    dholmes wrote: »
    Its really not that bad, just follow the directions from the AVS link I posted.
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
  • dholmes
    edited June 2008
    Thanks millerman,Integra suggested when I called them that I send it to a service center & let them up-date it,I may do that.I looked at avs forum & theres so many of them I dont know which one I need. I guess I need to one for my 805 & one for 9.8 When I try to go to one of the sites at avs I get some kind of rapid share place???
  • avguytx
    avguytx Posts: 1,628
    edited June 2008
    What firmware update did they say you need? I have v1.08 that I could email to you if you'll PM me your email address. It's simple to do as everything is in the files explaining it.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • dholmes
    edited July 2008
    Before everything went POP that hd sound is AAA+++ I didnt think it would be anything that great!!!
    edited July 2008
    My bad. I was thinking the DSP upgrade for the DTC9.8 was the same as the SR805, but now I see they are not. Sorry dude.
  • dholmes
    edited July 2008
    Why cant Integra just send me a upgrade cd & I pop in the dvd player & its done??
  • dholmes
    edited July 2008
    Thanks everyone for all your help after contacting Integra if I burn a cd I need a cd player not a dvd player so I think Ill send it to a service ct for upgrading,I dont want to buy a cd player just for this.
    edited July 2008
    dholmes wrote: »
    You can use a DVD player just as well as a CD player. The only condition is that the player is connected via optical to Opt1 input. Many people have used their dvd players to update the DSP.
    The trick is to get a good burn onto the cd. It has to be recorded as an audio cd, not a data cd. Do it at a slow burn speed. Make sure DVD is set to eliminate all audio manipulation. Another trick is to play a regular CD first (just for 30 seconds or so) to get the receiver in PCM receiving mode. Then put the update disc in and follow the directions.
  • cheddar
    cheddar Posts: 2,390
    edited July 2008
    Here is a quoted post on another forum that used a ps3 to do the update. Haven't tried it myself. But it's certainly possible with the equipment you have.
    Successfully updated my 605 yesterday evening using my 60GB PS3. I had tried using and older RCA DVD player and a new LG DVD player with no luck. Decided to give the PS3 a try and it worked. Not sure if all of these steps are required but I unplugged the HDMI cable coming from the PS3 out of the input on the back of the receiver and went straight to the TV. Optical cable from PS3 into Optical 1 on the back of the Onkyo. Under the PS3 audio settings (I think?) I unchecked all of the manual HDMI audio settings I could. Changed to optical output and unchecked all the boxes except for the 2 channel options. The optical ouput type I made sure was set to PCM. I think this setting is under optical output audio type or something like that. PS3 is updated to latest firmware. Played 15 sec. track and then receiver switched to writing and after about 20 seconds or so it completed, reset, and went into standby. Powered on 605 and checked DSP and it was the one I had burned onto the CR-RW. Hope this helps.
  • millerman 3732
    edited July 2008
    dholmes wrote: »
    I used my Panny BD player to update my 805 with out any problems.
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
  • dholmes
    edited July 2008
    I burned I think the file that avguytx emailed me ,I burned it a 4x speed & it only took a minute or so.So I ejected the cd from computer,put it back in & it showed the file.Did I do it correct??Im a little nervous trying it on the 9.8!
  • WilliamM2
    WilliamM2 Posts: 4,811
    edited July 2008
    It should play as an audio CD, you can test that before doing any updating. Turn your volume very low first.
    What did you use to burn it? Media player does not usually work, use something like Nero.
    edited July 2008
    dholmes wrote: »
    You should not see the "file", you should see an audio track. It has to be burned as an audio CD, not data. Use Nero. You can download a trial version that will let you burn discs.
    Don't worry about doing this. Its virtually impossible to 'brick' the unit by this CD method. It will either take or it won't. If you do get the upgrade to go, be prepared to fully run your setup again. The DSP update wipes out everything!
  • dholmes
    edited July 2008
    Thanks when I put the cd in my computer it showed the file.
  • dholmes
    edited July 2008
    If I put this burned cd in a cd player what am I supposed to hear?
  • WilliamM2
    edited July 2008
    It will sound like three buursts of noise, about 20 seconds each if I recall. Like I said, put the volume very low.
    It won't hurt to try the CD, the update won't happen unless you put the 9.8 in update mode.
    edited July 2008
    dholmes wrote: »
    It will sound kinda like a dial up modem sound or fax machine. Digital noise basically.
  • dholmes
    edited July 2008
    Thanks everyone!
  • dholmes
    edited July 2008
    Well I tried to burn to a cdr & it didnt work, when I down loaded the email there was 4 different things should I burn the application only? thanks Im sorry to be so computer challenged.
