Blue Ray / HDMI / Receiver Question
kevhed72
kevhed72 Posts: 5,202
edited July 2008 in Electronics
All-right...I believe I have this figured out via all the good existing threads on this site. If you have a newer receiver with HDMI inputs / outputs, then you can simply route a Blue Ray player to the receiver via an HDMI connection (and any other outputs such as 5.1/7.1 analog on the Blue Ray are not needed). I am assuming the HDMI is the preferred connection, in terms on quality of sound.
When purchasing a Blue Ray and Receiver, you want to ensure the receiver decodes all the different audio "formats" if the HDMI is routed from Player -> Receiver -> TV. Does this make sense? I guess some of the "fun" of this hobby is figuring all this out before purchasing the equipment...
Post edited by kevhed72 on
  • dane_peterson
    dane_peterson Posts: 1,903
    edited July 2008
    HDMI is the preferred connection, as its the only digital connection that will carry the new audio formats.
    Your receiver doesn't necessarily need to be capable of processing these audio formats... but your player then will need to to output them.
    From your receiver, all you really do is send video to the TV. No audio is necessary. Some HT enthusiasts argue the component cable produces just as good a picture as HDMI, but at the cost of 3 cables instead of 1. At that point it's up to you.
  • jjeckelxz5
    jjeckelxz5 Posts: 48
    edited July 2008
    be careful when choosing a reciever cus not all recievers with hdmi hookup process audio through hdmi
    reciever-Yamaha rxv1700
    front-RM50t
    center-RM30
    surrounds-M40
    rear surrounds-RM30
    velodyne minivee
    playstation 3
  • Shicks18
    Shicks18 Posts: 397
    edited July 2008
    whats your budget for a receiver? all the new HD audio codecs are being released on the new lines of receivers and at budget prices.
    2 to look at are:
    Pioneer VSX-1018
    Yamaha RX-V663
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Front Amp: Parasound HCA-1000A
    Center Amp: Marantz MA500
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
    Games: Xbox360 and PS3
  • Ethancf
    Ethancf Posts: 479
    edited July 2008
    5.1 analog interconnects will work for the new audio formats as long as the player can and is set up to decode the new formats instead of the receiver.
    THE SYSTEM
    Polk Audio LSiM 707 Mains
    Polk LSiM 702 f/x Surrounds
    Polk Audio LSiM 706 C Center
    SVS SB-17 Ultra Subwoofer
    Rotel RSP-1582 Pre/Pro
    Rotel RMB 1585 Amplifier
    Oppo UDP-205 Blu-ray Player
    Samsung PN64D550 64" Plasma
  • cheddar
    cheddar Posts: 2,390
    edited July 2008
    kevhed72 wrote: »
    Since you appear to be buying everything new, don't go looking for analog out compatiblity unless you need it for another purpose. You are correct that HDMI is the connection these pieces of equipment are designed to work with best (for example, some equipment omits analog outs entirely or only have 5.1 outs even if they're capable of passing 7.1 via hdmi). The most important thing is not whether the decoding happens in the receiver or the player. You should be looking at other features such as amplification requirements, sound quality of the digitial processing, and video upconversion/hdmi switching on the receiver side and video/upconversion quality and features you want (such as PIP commentary and internet connectivity) on the player side.
    Once you decide on a range of players and receivers, then it's a relatively easy task of choosing two pieces that mesh together to access the lossless audio.
    1. Decoding in either the receiver or player.
    2. HDMI connection between the two that passes decoded PCM from the player if decoding happens there. Also double check that the receiver can accept PCM. Most do.
    3. HDMI connection between the two that passes bitstream from the player if decoding happens in the receiver. You'll have a better chance to get this from new blu-ray players recently released.
  • kevhed72
    edited July 2008
    Schicks18 - My budget is around the 1200.00 range for a receiver, but it could go a bit either way pending on features and ability to run LSi speakers...I am attempting to build an HT system for the long-haul. I started building one about 8 years ago, then got married, dogs, kids, and it never materialized.
  • rtart
    rtart Posts: 854
    edited July 2008
    kevhed72 wrote: »
    Hi Kev (again),
    You may want to take a look at an older AVR with HDMI inputs, instead of a "bleeding edge" unit. Most BD players will output (almost all) of the new HD audio formats via PCM through HDMI. You don't need HDMI 1.3 to get this functionality. In fact, most BD players will not bitstream the HD audio sources into a new receiver, even if the AVR WILL decode the new format. Basically, the BD player must either decode the new HD audio format and convert it into PCM (which will pass through HDMI 1.1, 1.2 and/or 1.3), or the player must pass the "raw" data via bitstream to the AVR, which will then decode it, if it has that capability. (Most do not have that capability.) So, what's the best interim solution for BD (IMHO, of course)? Buy a PS3 (20, 40, 60 or 80Gb will do) and a HDMI 1.1 AVR. Put the extra money into the bank and wait until BD comes completely of age, and will decode or bitstream ALL of the new audio codecs, including DTS-Master HD.
    Sort of like what HD DVD players did on day one.
    There is a great thread on AVSForum entitled "Future proof AVR's" that's worth a read.
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
  • cheddar
    edited July 2008
    rtart wrote: »
    Actually CURRENTLY available equipment can do all of this now. DTS-HD Master Audio was not available in the electronics of any format until very recently. And the only studios to really release a lot of movies using it were blu-ray studios like FOX.
    What you might have to wait for is more choice in players if you don't like the Samsungs, Panasonics, etc. available now. But this seems to be a very standard feature on new receivers going forward. Just look at the good availability on new midrange receivers in the Denon/Onkyo lines.
  • kevhed72
    edited July 2008
    Guys,
    Thanks for the info. It seems waiting for some of the new Sony's or Samsung's may be the way to go. If I wait long enough, I may even get a deal after X-Mas ( I can hear all the retailer's crying already about the poor shopping season).
    RTART...I still have those speakers...I need to get rid of them. What was your price? I can maybe go even a bit lower. Or is the project completely dead due you don't have the subs...
