Denon AVR Setup Advice Please (xpost on AVS)
xandra
Just purchased a Denon AVR-3808ci - since bought from Crutchfield I've got 30 days to test.
Are there any owners here of this (or similar) have any setup advice...
Firstly: is it vital that run all the updates before doing anything else (not sure where my 100' enet cable is lurking)
ALSO:
Are there are any gotcha's, counter-intuitive settings, or options to look out for. (I'm already comfortable with Audysses setup - assuming similar to Onk's)
should it matter, will be connecting to: 2 dvd players (one does SACD), a panny recorder, TWCable box, Sony LCD, wii, iPod, And Parasound Amplifier
ALSO:
LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
Post edited by xandra on
u shud verify your firmware and apply all applicable patches... just to avoid figuring out problems as the original firmware was kinda buggy. the rest shud be normal hookups like the Onkyo.
Hi xandra,
I have the 3808 as well - damn fine machine! Yes, I ran all the updates as well and I have to tell you, the Audysses is essential. I listened to 2 channel initially with out the set up and it was a little depressing - running the auto setup transforms it to like a night and day difference. I still listen to 2 channel through Pure Direct, but the crossovers that the auto set up makes all the difference.
If you are as happy as I am, you'll be keeping it!Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200 -
jon: thanx for firmware advice, luckily found my 100 footer...
just can't keep connected permanently as my 8port router already maxed out. Assume I can plug it in from time to time to check for updates. Hope this will not be a prob.
VX: I concur, I'll be running Audysses (as soon as I can get dog out of the house) I'm really floored by how good a job it does.LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
If you have any other questions about the 3808, shoot me a PM.
RobMoney Talks, Mine says Goodbye Rob!!!!
