Polk Momo 6.5" comps vs. Focal 165 A1
Airplay355
I'm getting a new car (2000 Subaru Outback Limited) and I need to put new speakers in it since the front mids are blown. I currently have Polk Momos in my protege now and they are pretty nice. My only complaint (and this is running them off a Pioneer HU) is that they don't really play that loud. I blame this on the fact that I'm probably running them on 2 watts or something and the fact that they only have an 89db/watt efficiency rating.
I own a pair of JM Lab chorus speakers and I liked them better then the Rti's I used to own. I was wondering if Focal and Polk car speakers compared similarly. The focals have a 92db/watt efficiency rating so running them off a HU should be better then the polks but I've never heard them so I'm not sure If they'd actually sound better or just louder.
Are the Focals nicer then the polks? Can I trust listening rooms to find out for myself? Is there another pair of speakers I should consider in the <$200 price range?
I generally listen to electronic music but I have an SVS sub driver to handle the low end, so I'm not looking for my speakers to be subwoofers.
Post edited by Airplay355 on
Are you transferring your old speakers/radio to the new car?
I can't even imagine why anyone would spend time seriously debating the sonic differences between $200 components (such as between Polk and Focal) when they're just planning on running them off a HU. Makes zero sense to me.
And, yes, I said something irrelevant to your question since I can't actually answer your question!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
No. I'll be getting a new HU. My mom decided it was best to just let the old stuff go with the old car and get new stuff and who am I to argue
I'm debating the differences because eventually I'll get an amp and then differences will be audible so I'd like to buy the best speakers the first time around. -
Focals generally have better midbass but I always thought they were too bright.
The Momo's wont have as much midbass kick as the Focals but will be smoother overall.polkaudio sound quality competitor since 2005
take out the polks, get a nice HU, and the money you would have spent on speakers, buy a nice small 2 channel amp.
And get $10 cheapies to replace your polks with, if you have to leave something in the car -
OK you talked me into it. I'll keep the polks and my HU (it's a pretty nice one, atleast I won't find better for the amount Im willing to spend) and I'll get an amp.
What kind of amps do you guys suggest in the 200< range. -
IMO man if you're gonna have a nice set of Polk Momo comp u need a nicer amp than a $200 amp that's for sure. I would get a powerful 4-channel and biamp the Polks. That's what I'm doing with my Boston Acoustics and they sound awesome that way.
heya,
Good idea mate
Heres a killer amp at a killer price. I have the X200.4, and it runs my mids damn nicely on 2 channels, and 2 x Polk DB12's on the other 2 channels!
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5909
Its a Phoenix Gold X200.2 in case the link does not work, at www.woofersetc.com
Its not PG's latest amp, but a few years back was their flagship model, and sounds amazing.
If you want to bi-amp your splits (run the tweeters orr a seperate channel) you will have to get a 4 channel amp, but if you place th tweeters right, you can use the attenuator on the x-overs for the tweeters to get the splits sounding pretty good.
Hope that help. If you do not like that amp,check out that site, they got some damn nice stuff and cheap. You Americans are damn spoilt!
cya -
I was thinking of going with this amp. http://www.sonicelectronix.com/item_11204_Hifonics+TXi+6408.html
I don't need an expensive amp, I'm not building a competition system, just something to keep me satisfied on my 9 mile drive to school. I'm not looking to win any SPL contests. -
Amps don't just give you SPL. They also give you SQ (and you definitely know that from home audio).
If you don't think your SQ expectations warrant a 'nice' amp, then I don't think they should really warrant a critical look at MOMO's vs. Focals.
I don't know, maybe I'm being too harsh here. But those are my immediate thoughts, at least.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
I understand amps effect quality but I do not have an infinite amount of money to spend. I asked for the best amp that cost's less then 200 to use with the best speakers costing less then 200.
Focals and Momos are in the same price range and will sound different powered by the same HU or the same amp. Comparing them is a perfectly logical thing to do. I'm not comparing apples to oranges, the prices are within $15. Just because I'd be powering them with a lesser quality amp or HU doesn't mean they will sound the same.
If you have nothing productive to add to the thread then please post elsewhere. So far all you've done is criticize me for what I want. I do not need to warrant asking a question. Asking for advice on the best amp for less then 200 is certainly in line with what this forum was created for. -
The Hifonics amp would do fine if you bridge it, or you could use it to run eash component off a channel, although you may be underpowering the mids a tad on 85W.
The Phoenix Gold is an amazing amp for SQ, and would probably give you better sound (although I have not used the Hifonics so cannot say this for sure).
It is a little more, but would last a long time, and be an amp you could keep for years to come.
But in essence, either amp would do you fine, so go with the one you think is better, as you are the one that has to have it in your car
cya -
Wow, did someone get up on the wrong side of the bed this morning? Did I really come across as that critical? If so, I apologize.
Happy hunting...hope you find the amp you want.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Not big on Hifonics. Shaky build quality and they have a tendency to not make their rated power.
Here are a couple suggestions:
You can get one of the new Polk amps for $230 shipped and fully authorized from Crutchfield. I use these amps in competition and so far after 4 shows this season, theyre undefeated....with 2 best of shows!
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=120&i=107PA2502&tp=115
2nd choice would be this Rockford Fosgate for $140 shipped.
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=120&i=575P3252&tp=115polkaudio sound quality competitor since 2005
Mac,
I do like the polk amps a lot even though they are a little pricey for me. I'd rather get a 4 channel one so I could bridge one channel to use with a sub. Do you think think that's a bad idea?
Is buying used car audio not smart? I wouldn't mind buying one of the older discontinued Polk amps if I could get more for my money. -
maybe i should spend the extra $100 and get one of these? http://www.highdecibels.com/proddetail.asp?prod=PA500%2E4
hey,
That polk amp above is nice, but imho, 250watts bridged is not going to run many subs to their fullest of their abilities (even the db series runs at 400w rms)
I would buy a nice 2-channel amp, and a nice mono when you add a sub.
2nd hand is not a bad idea, but there is always a risk involved, but its a great way to get bargains. Just make sure you buy froma reputable person (ie, someone well known on forums, and that has not just joined etc).
Last years models are another great way to save, as like with the PG i posted ealier, you get good bargains for very very good amp.
goodluck -
Why isn't 250 enough? I don't understand the whole car audio wattage thing. I'm an HT guy and 250 watts is plenty. Whats the difference?
I'm using an SVS sub driver and I can put it into whatever size box I like and I'm not trying to win competitions, just trying to have some bass. -
250 watts is plenty in home audio simply because of the noise floor. In your car, youre going to have to overcome around 80 db of road and wind noise. 250 watts can get over the excess noise but you want have any bass with authority. 500 watts is a good amount of power that wont break the bank but will have enough hutzpah to overpower road noise.polkaudio sound quality competitor since 2005
why have 500, when you have 4kw?
Then again...maybe 4kw isnt for everyone.
so 500 watts for a sub is a good amount...
What about my components? Is 85 from the polk amp you suggested good enough?
I just don't have any experience with any car audio. I've owned plenty of home audio stuff so I know what to expect and what features certain gear will have but I have no idea what any amps are going to sound like. -
crutchfield is authorized, but it also pretty expensive.
For people on a budget, I like www.onlinecarstereo.com
A lot of other people have success with www.sonicelectronix.com
You can get much more amp for your money.
I would strive closer to the 100x2 mark for your components.
More power is always better to a point. If you can afford 150 watts per channel then that would be better but 85 aint no slouch. There is a point where youre paying for power youll never use and to me 150-200 is about all you should ever get for mids/highs. Sure you can put 500 watts per driver but youre never using more than 150 so why bother? Its like putting a bad **** 500 hp engine in your car but never driving more than 35 mph.
It also depends on what youre wanting. If youre just wanting some tunes to listen to while youre driving to work then you dont need a lot of power. However if youre wanting to get the best sounding system you can then get the most power you can afford.polkaudio sound quality competitor since 2005
Alpinepolkaudio sound quality competitor since 2005
