About finished tweaking my SRS's. They're now light, delicate and airy
candyliquor35m
candyliquor35m Posts: 2,267
edited June 2008 in Vintage Speakers
The soundstage and imaging is better than before. Dead quiet except for the music. I can now pick out the bass pedal hitting the bass drum. Something I had never been able to do before. Incredible separation of all instruments and vocals.
amp: golden tube se-100, 10 mullard el-34 xf4 tubes
pre: conrad johnson pv-10al, 2 tf 12ax7 tubes
cdp: ah 4000, 2 tf e188cc tubes
ic: aq king cobras
sp. wire: romex 10 ga solid core copper
sda ic: stock
test cd: dire straits, bia
volume: 9 o'clock
Post edited by candyliquor35m on
    treitz3 Posts: 19,989
    edited June 2008
    Got cap?
  • avguytx
    avguytx Posts: 1,628
    edited June 2008
    treitz3 wrote: »
    Got cap?
    That's just what I was thinking Tom. Were those simply stunning, awesome, technology defying capacitators (pun intended) used?
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • daifanshi
    daifanshi Posts: 46
    edited June 2008
    avguytx wrote: »
    What's a "capacitator"? Is that anything like a capacitor?
    Anyways, I ran a few quick simulations of candyliquor's additional cap on the SDA 2B. What appears to be happening is that the highpass 2nd order filter has it's 40dB/decade slope being increased to 60dB/decade by the addition of the capacitor. The actual crossover frequency is not changing much. There is some peaking near the crossover point.
    The end result is that at 100Hz, the filter function has 90dB rejection versus 50dB or so for the high pass section of the original crossover.
    Increasing the rejection slope will improve the power handling of the tweeter since it won't have to deal with out-band-power at the same level. Unless the tweeter is made specifically for high excursion and power handling, a lot of tweeters will suffer (sound distorted, strident, strained, or whatever word you want to use.)
    Only a few tweeters can deal with BOTH a low crossover frequency (some as low as 1500Hz!) and 1st order highpasses. The EPI/Burhoe inverted dome comes to mind.
    So Candyliquors "fix" may not be as far fetched as it sounds. And one shouldn't dismiss it outright. It begs to be looked at more carefully...
    Cheers.
    F1nut Posts: 51,760
    edited June 2008
    It has been looked at and if you don't mind a 29dB suck out at 3kHz, go for it. :rolleyes:
  • daifanshi
    daifanshi Posts: 46
    edited June 2008
    I looked at one case and that was the SDA 2B. Now I haven't simulated all of candyliquors fixed for the various Polk models he's modified. But the SDA 2B doesn't appear to exhibit a suckout.
    Do you have a plot of the SDA 2B with the fix? I have some plots of one of the RTA models with a fix. But the scale is ridiculousy coarse (20dB) steps, so it's hard to conclude anything.
    F1nut Posts: 51,760
    edited June 2008
    We've hashed all of this out before. It's a bad idea any way one looks at it.
    The fact that you are even considering it along with the fact that you think VCR cables make good interconnects and that a 6 channel Kenwood AVR makes for a good amp has earned you a place on my Bozo List. C ya!
  • daifanshi
    daifanshi Posts: 46
    edited June 2008
    I'm happy you're resorting to name-calling. It must make you feel superior.
    Back to the subject. If the deep suckout (29dB is pretty deep) is happening at 3.0khz it's probably destructive interference at the crossover point. And the phase difference has to be fairly close to 180deg. We could confirm this rather quickly if the original person who ran the test could invert the polarity of the tweeter. The null should be a shallower or possible go the other way and cause minor peaking near the crossover point.
    For those who are interested in building their own speaker systems, inverting the tweeter or woofer is a good sanity check for determining if the crossover point is summing correctly.
    heiney9 Posts: 25,432
    edited June 2008
    Maybe you and CL35M can have dinner sometime.
  • avguytx
    edited June 2008
    daifanshi wrote: »
    It's a play on words....like it said in parentheses. "Pun intended".
  • Fatwalnut
    Fatwalnut Posts: 54
    edited June 2008
    Light, delicate and airy. Sounds like your SRS's are some kind of yummy muffins lol. "sorry :-)"
  • Face
    Face Posts: 14,340
    edited June 2008
    Aside from the SL1000, the SL2000 is the most shrill tweeter I've heard from this lineup. Are you sure yours are even working? Maybe your poly's or crossover caps are dead? :D
    I still can't get over how smooth the RD0-198 is, and how vast of a difference the 4.1TL upgrade made.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited June 2008
    [QUOTE=I still can't get over how smooth the RD0-198 is, and how vast of a difference the 4.1TL upgrade made.[/QUOTE]
    I'll second that.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • candyliquor35m
    edited June 2008
    It's like night and day and the caps are still burning in.
    The light and delicate highs are still there but the harsh mids that were being fed to the tweeters are gone forever.
    When I tried .47 uf/mfd caps on all 4 tweeters, it removed too much of the mids and I began to lose soundstage and imaging so I changed them to 1.0 uf/mfd caps on the middle 2 tweeters and the soundstage and imaging returned.
    These are radial mylar caps which from what I understand are non-polarized.
  • amulford
    amulford Posts: 5,020
    edited June 2008
    Lemme get this straight. You put these caps right at the tweeters, right?
  • NotaSuv
    NotaSuv Posts: 3,871
    edited June 2008
    Funny how the same "chit dont stink members" keep this crap going ;)
    even though they have instructed the lower ranks not to
    gotta be the PPT
    polk power trip ;)
  • candyliquor35m
    edited June 2008
    amulford wrote: »
    yes sir, plug and play
    http://www.polkaudio.com/forums/attachment.php?attachmentid=31246
  • daifanshi
    daifanshi Posts: 46
    edited June 2008
    Have you tried switching the polarities of your tweeters? The added phase shift from your 18dB/oct tweeter high pass filter may be producing a suckout near the crossover frequency.
  • candyliquor35m
    edited June 2008
    NotaSuv wrote: »
    Funny
    Maybe because I'm not attacking anyone or calling them names.
  • candyliquor35m
    edited June 2008
    daifanshi wrote: »
    No but I can do it right now. Would this happen even if the caps aren't polarized?
  • daifanshi
    daifanshi Posts: 46
    edited June 2008
    Your mylars should be non-polarized, but if you DC reverse bias a polarized cap enough, it will go "poof". Sometimes in a very spectacular fashion.
    But I'm not sure what will happen from an audibility perspective if you have low level AC going through a polarized cap. It will probably still work to a certain point. Definitely no-optimal.
  • candyliquor35m
    edited June 2008
    daifanshi wrote: »
    Right now I'm enjoying the music. I'll try to do it later.
    Would I hear a difference by just changing 1 tweeter or will I have to do all 4 to hear a difference in that speaker?
  • amulford
    edited June 2008
  • candyliquor35m
    edited June 2008
    amulford wrote: »
    OK. What does it do for you?
    It's changing the crossover point just enough to block the harsh mids that were being fed to the tweeters.
    The sl2000 isn't harsh because of the upper frequencies, it becomes harsh when too low of a frequency is fed to it (vocals, snare drum?, etc). You definitely need some of those frequencie fed to it because that's what gives you the wide soundstage.
    If I continue to use a smaller and smaller value cap, the cap will block all the mids from getting to the tweeter but I won't have any soundstage left.
  • amulford
    edited June 2008
  • nspindel
    nspindel Posts: 5,343
    edited June 2008
    Face wrote: »
    I'll third that.
    The 2B is a fantastic speaker, if you treat it right. Rebuild the XO's, do the TL upgrade, and get the RD-0198.
    You don't need to do anything else to the tweeter. Just install the 5.8uf cap on the XO, and it will sound gorgeous.
    This debate of the cap inline with the tweeter is really getting old and boring...
  • daifanshi
    daifanshi Posts: 46
    edited June 2008
    Candyliquor35,
    You really need to do all of them to preserve the correct relative phasing of what Polk calls the "disappearing point source".
    If I may make a suggestion for simplifying your mod. If adding the caps is steepening the highpass crossover slope, you can achieve an equivalent result by putting only ONE additional cap right after the first crossover cap instead of having separate caps for each tweeter. This will look like a "T" shaped 3rd order network. You'll need to determine what value that cap needs to be. If you're using 1uF now, try that first.
    If the the SDA SRS has biamp terminals, you can easily invert the tweeter array simply by swapping the + and - terminal connections to your amplifier for the tweeter inputs. Or if you only have one amplifier driving these speakers, connect the jumpers black to red for both pairs of terminals, instead of red to red and black to black. This will effectively invert the phase of all the tweeters relative to the woofers without needing to mess with the crossovers. All this is possible because the tweeter and woofer networks have separate grounds.
