Center Speaker placement
gimmepilotwings
Hello all.
New user here, but I have an ok setup with RTi10's CSi5 channel and R50 surrounds.
I am currently having a dilemma with the placement of the CSi5. I have a Sony KDS60A2020 TV and I need some mounting/shelfing options for this TV. My current TV stand does not have any openings for speaker placement, so ATM that is not an option.
I have a seen a couple solutions from Omnimount, but they don't seem to be able to handle the dimensions of the CSi5 very well.
What are you guys using to mount this speaker?
Any help would be appreciated.
Thanks,
Thanks,
Post edited by gimmepilotwings on
If you decide to get a new stand, I can only say that I have a Sanus and love it.
http://www.sanus.com/us/en/products/productCategory/line/speakerFoundations/pcat/flatPanel/MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s -
how far is your t.v from your wall i would build a mount above the t.v and place it there imo- This your Bush?
Pioneer Elite Sc-25
Polk Lsic,15's,9's, PSW1000 -
Email these guys and they will tell you exactly what a good solution is (no afil):
www.standsandmounts.comMy Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
Getting a new stand is out of the question right now. I just got this one less than a year ago, and I don't have the funds to get another.
I had built a shelf that connected two bookshelves together just above the TV, but the new house that I am moving into doesn't have the same amount of wall space, so I need to come up with a better solution.
I'd have to say that the TV sits out about 2.5 ft from the wall. I can build something there if I have to, but I was trying to avoid it.
I'll try emailing standsandmounds.
Thanks,
