Parasound Halo A-21 & P3 vs New Classic 2250 & 2100 vs Rotel RB 1080 and RC 1082
Beta
Still trying to decide between the Parasound Halo A-21 & P3, the Parasound New Classic 2250 & 2100 or the Rotel RB 1080 and RC 1082? Any fedback on these products would be appreciated.
I actually called the Parasound tech department this AM. I spoke to a guy who said the differences between the A-21 and 2250 would be fairly nominal. If this were the case, I would choose the 2250 and the 2100 because of their look (I like the black on the New Classic better than the stainless on the Halo). Plus, the Halo is a bit large at +/- 19 inches in depth. It is hard to believe the sonic differeces would be nominal given the price difference between the Halo and New Classic lines.
Don't know a whole lot about the Rotel.
Thanks for your thoughts!
Post edited by Beta on
I would go for the Halo line. If you saw them side by side nekked you could see the difference in the build quality. That's what you are buying and more. I own a number of the Halo line products and they are definitely smoother, with a more detailed and deeper sound stage. The Halo will make a big difference if you have good speakers. If money is tight, the Parasound Classic series will do very well.
Good luck and welcome to Club Polk!Carl -
Tne differences are nominal due to the diminishing returns on most gear at this level. Each zero added to such nice gear results in less increase. They call it refinement not improvement.;)HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Halo hands down, just beautifully made equipment in sound and looks.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
