$700 Budget... best Polk fronts?
Shicks18
Shicks18 Posts: 397
edited June 2008 in Speakers
Open to all options.
This will be for a 7.1 setup. 70/30 for HT/Music. Whats the best I can get for $700? +/- $100 on the budget depending on whats available. If there is something outside of Polk I am open to it as well.
Thanks!
Scooter
TV: LG 55LW5600
Pre: Marantz SR6001
Front Amp: Parasound HCA-1000A
Center Amp: Marantz MA500
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
Games: Xbox360 and PS3
Post edited by Shicks18 on
  • Face
    Face Posts: 14,340
    edited June 2008
    Used LSi15's. Be prepared to budget for a timbre matched center and rears(LSiC, LSi7, 9, 15, or FX).
  • SlowcarIX
    SlowcarIX Posts: 887
    edited June 2008
    do you mind getting used?
    3 LSi7 or LSi9 for L/C/R will be real nice
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • Shicks18
    Shicks18 Posts: 397
    edited June 2008
    wouldn't mind getting used at all.
    Would adding a nice big subwoofer to the LSi9's match tower speakers + sub?
    edit - why did you get rid of your LSi15's for LSi9's ?
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • Face
    Face Posts: 14,340
    edited June 2008
    Shicks18 wrote: »
    For HT, a sub would be needed for LSi9's or 15's.
  • Shicks18
    Shicks18 Posts: 397
    edited June 2008
    Yea I am gonna upgrade to a bigger sub regardless of my fronts.
    Basically whats the difference between LSi9's and LSi15's using a big sub for bass on both.
    Also - How do LSi9's compare to RTi12's in terms of loudness and quality.
    Thanks.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • Face
    Face Posts: 14,340
    edited June 2008
    For 2 channel listening, the 15's are a full range speaker and wouldn't require a sub. Some use the 9's for music without a sub, but only in smallish rooms.
    As for LSi's vs. RTi's, if you're going to be listening to music, LSi's win hands down.
  • Shicks18
    Shicks18 Posts: 397
    edited June 2008
    70/30 for HT/Music
    How loud does the LSi9 or 15 compare to the RTi12's
    These are the 3 speakers I am considering.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • SlowcarIX
    edited June 2008
    Shicks18 wrote: »
    yes. 2 things i did not like about the LSi15 is high xover to the internal sub and the side firing sub, you are limited to where you can place them to get the best sound. so i went with lsi9 and a sub that i can place to give the best sound.
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited June 2008
    Shicks18 wrote: »
    Thanks.
    this is comparing a CSi5 and a LSiC...
    the tweeter on the CSi5 gets a bit shrill when the volume is cranked up compared to the LSi tweeter...they are mellow...very easy on the ears
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited June 2008
    Shicks18 wrote: »
    70/30 for HT/Music
    the 3 will play loud, your ears will give up before the speakers.
    go with the lsi, good for ht and music
    my 7.(1x4) HT setup
    Buttkicker
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited June 2008
    Modified SDA 2B's to the TL spec with Sonicaps. If you look around you can do it for a good bit less than $700 and your 70/30 split will switch to favor music rather than HT. IMHO YMMV.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • McLoki
    McLoki Posts: 5,231
    edited June 2008
    If you are willing to go used, I would not overlook the SDA series either. 1c's would be easy on your budget. If you look hard, you could walk into 3.1tl's or 2.3tl's. That would require a little luck and patience on your end though.
    End result may be worth it to you. Definately a different sound than the LSi's and a more classic speaker look. They would be considered at least the LSi's equal if not better.
  • McLoki
    McLoki Posts: 5,231
    edited June 2008
    Damn - missed it by 8 min. I meant to say - listen to Scott.... :)
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2008
    Well his budget is going to go right out the window with any purchase of the LSI's since he will also have to get proper amplification for them if he really wants to hear them at their best.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited June 2008
    cfrizz wrote: »
    And a receiver with pre outs as well.
  • jcaut
    jcaut Posts: 1,849
    edited June 2008
    Don't overlook the new TSi line.
    If I can get it edited, I'll be posting a review of the TSi500's shortly. Scroll down a few pages and you should find another one.
  • Shicks18
    Shicks18 Posts: 397
    edited June 2008
    Nono, my budget will be totally fine. I am budgeting $700 for speakers.
    I have a Yamaha RX-V663 with preouts. Do you think the Yamaha RX-V663 can handle a 4 Ohm Load?
    I am also Budgeting $400 for an external amp, which I will have to decide on later depending on the speakers I get.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • cfrizz
    edited June 2008
    The Yami will handle them at low volume, just don't get too carried away. If you plan on getting an all LSI setup, you will need a 5-7 channel amp with at least a minimum of 200wpc to really hear what they are capable of.
    But if you are just going to have the front speakers then you should be able to find a 2 channel amp to get the job done.
    Some brands to look at are, Outlaw, Emotiva, Rotel, Parasound, Sunfire, Adcom.
  • Shicks18
    Shicks18 Posts: 397
    edited June 2008
    Yea I planned on Bi-Amping whatever speakers I get with the Yammy and a dedicated amp.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • MillerLiteScott
    edited June 2008
    Schicks, where are you located?
    Also with most of the vintage SDA 2B's,1C's and there other cousins of do not need to be bi-amped.
    My case was a pair of SDA 2B's with the sonicap upgrades and RDO -198's for @ $575. Local pick up is the key.
    Scott
  • RutgersFTW
    RutgersFTW Posts: 458
    edited June 2008
    If it's $700 just for fronts, he could get LSi9s off eBay and an amp to bi-amp with, but...
    Why no love for RTis? They own this budget bracket and will play nice with the amp he already has.
    The TSis sounded an awful lot like Monitors to me when I checked them out at BB. Listening conditions weren't the best, but once the newness wears off I don't think anyone's going to recommend them over RTis. That's not to say they aren't also great, but RTis are already a fantastic value.
    Currently listening to:
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Audio Technica AT-LP120
    Mirage CMD-5 x 5
    Bic H-100
  • obieone
    obieone Posts: 5,077
    edited June 2008
    IF, IF, IF you live near a Tweeter, check out the clearance page.
    They're selling RTi10's for $480/ pr.
  • Shicks18
    Shicks18 Posts: 397
    edited June 2008
    There is a tweeter by my house in Houston. Considered the RTi10's as well.
    Only problem is I'm living here for the summer before going back up to Missouri (thats where my set up is). I could local pick up things but then ship up to missouri (looking at + $200 shipping which I don't mind doing but that cuts into my budget a little.)
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • deep bass
    deep bass Posts: 86
    edited June 2008
    I am not sure where you are located, however there is a pair of Polk Audio 2.3TL's in Seattle for $1,200. Maybe you can get him down on the price... (just a thought)
    http://seattle.craigslist.org/oly/ele/725624861.html
  • Shicks18
    Shicks18 Posts: 397
    edited June 2008
    Located in Houston,TX and Columbia,MO.
    That is more than likely way out of my price range =P
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • Shicks18
    Shicks18 Posts: 397
    edited June 2008
    bummer someone on here must have seen the refurb you posted... its been dropping $10 in price every 3-4 days now.. was waiting for it to drop even further. ive had my eye on it =P
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • leroyjr1
    edited June 2008
    Shicks18 wrote: »
    sorry its my fault
  • Shicks18
    Shicks18 Posts: 397
    edited June 2008
    hah naw its all good. I was leaning more towards LSi anyway. Can't make any sort of speaker purchase for another 7 weeks, they wouldn't have lasted that long on amazon.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
