EAC and Flac users
tryrrthg
I am thinking of adding some flac files to my music library. I've just started compiling my music server with music and they will primarily be wav files for the music I listen to the most. Some of the other music that I'd like to have available but I might not listen to as much I'd like to put in flac.
Since I've never used flac before with Exact audio copy I was wondering what everyone's command line reads?
mine is currently this, but I don't know how or why it looks like that...
-6 -V -T "ARTIST=%a" -T "TITLE=%t" -T "ALBUM=%g" -T "DATE=%y" -T "TRACKNUMBER=%n" -T "GENRE=%m" -T "COMMENT=%e" %s -o %d
also, what bit rate are you using with flac files? currently mine is set at 768.
Any help would be greatly appreciated! Thanks!
Post edited by tryrrthg on
Too lazy too look up my command line. All it does is display the info in the tag to be displayed in whatever media program you are using to play the file. I make tags in Media Monkey so the setting for the tag in FLAC for me aren't important.
As far as the bit rate there is no difference in playback quality it's just a matter of how much space you want them to take up I use level 8 which is the highest compact rate meaning it makes the smallest files but it also takes the longest to encode. If you are using primarily .WAV files for your server (why you wouldn't use FLAC I don't know
) then space must not be an issue so using a lower FLAC compression setting will mean faster encoding but the files are bigger.
I would use FLAC for everything there by saving space.
I also highly, highly recommend Media Monkey for your playback and file management. The free version is 99% as good as the pay version.
Check it out is a great, powerful easy to use music manager/player
www.mediamonkey.com"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
The ONLY reason I have all my music on my computer in .WAV is because it's so easy to just burn a CD for me or someone else when it's in .WAV. How hard would it be to burn a CD (that could play in all CD players) if you had it on your computer in FLAC?
I'm just thinking, with me fixing to go off to college and leaving all my CD's here, I want my music to be in the most versatile file format.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Thanks for the info H9. I will likely use flac for CD's I don't use that often and that I have a hard copy of already...audiobliss wrote: »The ONLY reason I have all my music on my computer in .WAV is because it's so easy to just burn a CD for me or someone else when it's in .WAV. How hard would it be to burn a CD (that could play in all CD players) if you had it on your computer in FLAC?
That's kinda my thoughts too. wav is just too versatile for making CD's, still uncompressed, etc. I don't have THAT many CD's so if I run out of space I'll just go buy a TB drive for my music server. Or I'll just delete wav files I never listen to...Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
With a program like Media Monkey you can burn FLAC to WAV on the fly no conversion nec. You guys do what you want. With storage being so cheap now days perhaps .WAV files will be the norm. FLAC is great for uploading like I do for my blog and it saves space on a hard drive, but if you have lots of space there is nothing wrong with .WAV files. Although typical .WAV files can't have tags although Media Monkey allows you to tag standard .WAV files."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
If you burn with Nero, they have a flac plug-in. So you can add flac files straight to an audio-cd burn project, and it will do the decompression to wav for you on the fly. Works perfectly. No need to store the files as wav just to make audio cd-burning more convenient...Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Very easy, Nero has a plugin as said, and many of the Linux burn software has it built-in. I am however considering going from FLAC to WAV since PS3 does not support FLAC. -
Ok, wow. Great to know all that. I'm definitely going to play with FLAC and Media Monkey, now. I'm out of space on my 250GB HD for WAV files, and was going to get a 500GB to do the job. But I'll check out FLAC first and see how that works.
Thanks for the info!!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
check out dbpoweramp as well, especially for doing your transcoding.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Ok, so I just d/l'd and installed MediaMonkey and am playing around with it a bit...what about a FLAC codec for EAC? A certain preference/recommendation? I'm not sure I know how to set it up even if I d/l the right one.
Any helpful write-ups or tips on it? Think I'll check out google real quick...
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Awesome! Thanks for that link! I've installed it and set it up almost completely so far.
So now I'm trying to setup my command line and I think I have most of it figured out. I'm just basing mine off what you posted in your first post, tryrrthg. However, a few questions. What's the %e, %s, %d, and -o do?
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
I'm not really sure what is up with my command line... it was just there...
as for the %e, %s, %d, and -o do, etc. I think those are what you want the file named when it is ripped. each of those stand for something. I would check your naming scheme in the EAC setup options it should show you what those stand for.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
