Emotiva CD Player
Early B.
Emotiva is currently designing a solid state CD player. It should be available in a few months. Here are some initial specs:
I'll post prototype pics once they become available to the general public.
- 24 bit processor with 384 x oversampling
- 4 independent power supplies
- capable of producing 7 volts of output
- slot-load system
- weighs around 30 pounds
- expected retail price is $499
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
Whats with crazy upsampling these days? I was just reading about those 32bit dacs, it all seems like such overkill.
Sounds interesting though, but I would never buy one. 7v is way to much output IMO, hell 2v is more than enough for most systems. -
I'd like to know more about the 7-volt output thing. This spec is sometimes found on high end CDPs. Maybe someone can explain it?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
with the high voltage, you can bypass a pre and drive an amp directly
wadia iirc has high voltage on there cdp toomy 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
If you bypass the pre, does the CDP have a volume control? -
Either that or listen reeeaaaallllyyy loud. Actually 7v would overload most amps and cause damage. If you bypass the pre you could use attenuators, not direct but the next best thing.
I listen with passive pres in all my systems and 2v is more than enough for me. Hell I had a .3v source which was enough gain, and thats with 2v input sensitivity amps.
Are these going to be similar to the Onix CDPs? -
Not me. I just hook my CDP straight to my amp and listen at line level. Oh ya...
I'd be interested to check it out when it is released as well. They have done well in the "budget" market on other products and this may do well as well. -
they should...and should be manipulated within the digital stream to avoid mechanical contact volume controls...my 7.(1x4) HT setup
Buttkicker
the CDP would need to have variable audio output RCA connectors.. some CDP's have them.PolkFest 2012, who's going>?
Ric Schultz was famous for this. He felt pres colored the sound to much so he went passive. That wasn't good enough so he made his Ultimate Attenuators. That wasn't good enough so he went straight from the CDP->Amp but it was to loud, so rumor has hit he now solders single resistors into the signal path. If he wants to change the volume he breaks out the soldering iron. -
That's pretty awesome Gaara. That would be a pain in the butt to change the volume, but talk about a pruist!
