Whats the best HDDVD player for my 2ch setup.
fbm211
Hi all.Im going to buy a hddvd player but cant figure out which one has a "very good" analog sound output for my system and also I want great upconverting too.My cheap insignia tv has HDMI and goes up to 1080i.Id like it to be able to play CDs also since my adcom is outdated and doesnt play older cds.(very bad tracking) Im thinking about getting a 8ft mini to rca from signal cable and using my pc for playing CDs.I have a good Xfi fatal1ty pro card and wonder if it would have better sound quality than the old adcom.Anyone out there know if thats the best way to do it???
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
I have a 2 channel system in my living room and use a Toshiba HD A30 connected to a Sony 2 channel receiver via analog with my HP LT-3200 32" LCD. Great upconverting player and can be had for less than 100 bones.THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma -
why not go with blu ray since hd dvd is now obsolete?reciever-Yamaha rxv1700
front-RM50t
center-RM30
surrounds-M40
rear surrounds-RM30
velodyne minivee
playstation 3 -
Well I was looking at some of those that do both but its still to costly.I dont want to pay 300-400 for something thats only a little better than something I can get for 50-80 bucks.And the hddvd movies are pretty cheap now too.Plus I really want to get that eagles farewell hddvd.That should sound sweet on my SDA-2Bs.SDA-2BTL with custom IC
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
People say the first generation players had the best sound quality - apparently they had superior DACs (Burr-Brown i believe..not sure WHICH burr browns). Can't say I've compared the two myself. The XA1 is widely believed to be the best in audio quality although the XA2, per most reports, isn't far behind. The XA1 plays MP3s and I don't believe the XA2 does. Video wise I'm fairly certain the XA2 is light years ahead of the XA1. Moral of the story: you can't win. If you need more info a quick search at avsforum will get you an entire thread on this topic.
Cheers
NM -
I have an XA1 and find it more than sufficient for music / audio.
Not sure what they cost these days or where to find them. They are built like tanks and move just as slowly. Dual copper chassis, beautiful looks (if you ask me). A pleasure to look and listen to.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
