External phono pre amp recommendations?
Erik Tracy
So, I'm considering an external phono pre amp for use on my avr - one with variable gain so I can match input levels between my other avr sources (BD, CD, STB).
Any recommendations or experiences other members would like to share?
I'm thinking of this unit here:
http://www.phonopreamps.com/TC-760LCpp.html
Thanks,
Erik
Thanks,
Erik
Post edited by Erik Tracy on
I have a Dynavector P-75 that sounds really nice.
What's your budget?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
I forgot to add that - and I should have known better!
$100-$200 is about what I can afford for now.
Looks like that fine dynavector is a bit out of my reach!
Thanks,
Erik
Bellari VP129
Works great, highly recommend, can be had for about $175.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
What kind of cartridge are you using? If you can solder, you can buy a Bugle kit from Hagerman technology and can customize the gain when you build it. Best low priced phono amp for the money.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
My recommendation as well. You'll have enough money left to buy some new vinyl.Wristwatch--->Crisco -
The mentioned belari the parasound and the NAD are good entry phono pre's.
RT1 -
The Cambridge Audio 540P. I have this one and it is a very nice inexpensive phone pre.
http://www.audioadvisor.com/prodinfo.asp?number=CA540P
The Cambridge Audio next step up would be the 640P....
http://www.audioadvisor.com/prodinfo.asp?number=CA640P"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Hagerman Cornet or Bugle; Bottlehead Seduction. Gotta melt some solder though.
www.hagtech.com
www.bottlehead.com
The underpinnings of a Seduction...
Don't believe anyone commented directly on your request for a phono pre with variable gain. Variable is different from adjustable gain, and raises the ante. I built the Hagerman RIPPER, which does have a variable gain adjustment knob. That is excellent. Apart from this, to achieve true variable gain, you likely need a lot more cash outlay. Just build a Bugle as mentioned and solder in the resistors needed to achieve the pre-set gain you are looking for. Cheap and outstanding!! I have Hagerman's Cornet2, Ripper and Bugle. Trust the recommendations for Hagerman products. You can't go wrong.
