External phono pre amp recommendations?
Erik Tracy
Erik Tracy Posts: 4,673
edited June 2008 in 2 Channel Audio
So, I'm considering an external phono pre amp for use on my avr - one with variable gain so I can match input levels between my other avr sources (BD, CD, STB).
Any recommendations or experiences other members would like to share?
I'm thinking of this unit here:
http://www.phonopreamps.com/TC-760LCpp.html
Thanks,
Erik
Post edited by Erik Tracy on
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited June 2008
    I have a Dynavector P-75 that sounds really nice.
    What's your budget?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Erik Tracy
    edited June 2008
    I forgot to add that - and I should have known better! :p
    $100-$200 is about what I can afford for now.
    Looks like that fine dynavector is a bit out of my reach! :o
    Thanks,
    Erik
  • unc2701
    unc2701 Posts: 3,587
    edited June 2008
    Bellari VP129
    Works great, highly recommend, can be had for about $175.
    Backburner:Krell KAV-300i
  • bikerboy
    bikerboy Posts: 1,211
    edited June 2008
    What kind of cartridge are you using? If you can solder, you can buy a Bugle kit from Hagerman technology and can customize the gain when you build it. Best low priced phono amp for the money.
    Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
  • strider
    strider Posts: 2,568
    edited June 2008
    bikerboy wrote: »
    My recommendation as well. You'll have enough money left to buy some new vinyl.
    Wristwatch--->Crisco
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2008
    The mentioned belari the parasound and the NAD are good entry phono pre's.
    RT1
  • shack
    shack Posts: 11,154
    edited June 2008
    The Cambridge Audio 540P. I have this one and it is a very nice inexpensive phone pre.
    http://www.audioadvisor.com/prodinfo.asp?number=CA540P
    The Cambridge Audio next step up would be the 640P....
    http://www.audioadvisor.com/prodinfo.asp?number=CA640P
    mhardy6647 Posts: 33,964
    edited June 2008
    Hagerman Cornet or Bugle; Bottlehead Seduction. Gotta melt some solder though.
    www.hagtech.com
    www.bottlehead.com
    The underpinnings of a Seduction...
  • analog97
    analog97 Posts: 328
    edited June 2008
    Don't believe anyone commented directly on your request for a phono pre with variable gain. Variable is different from adjustable gain, and raises the ante. I built the Hagerman RIPPER, which does have a variable gain adjustment knob. That is excellent. Apart from this, to achieve true variable gain, you likely need a lot more cash outlay. Just build a Bugle as mentioned and solder in the resistors needed to achieve the pre-set gain you are looking for. Cheap and outstanding!! I have Hagerman's Cornet2, Ripper and Bugle. Trust the recommendations for Hagerman products. You can't go wrong.
