computer help
BAD ASP
Anybody out there know a download that will help solve this:
I keep getting runtime errors and the prompt asks if I would like to debug. I say yes and it takes me to a dialogue box that shows an error line and a continue or break option. I press continue and nothing happens. I press break and a line appears and then nothing happens. I then press cancel and it asks me if I want to stop debugging. I don't know if I am debugging because nothing happens. This is on my work computer and its becoming a real pain in the ****. I googled run time error debug and there are a number of free downloads to assist but I am wary of which are useful and which are disasters.
Any help would be greatly appreciated!!!
Amp: sunfire cinema grand signature 5ch 425 wpc
Side surround amp: Sunfire 2 X 300
Processor: sunfire theater grand V
Fronts:: polk sda-srs 1.2
Rears: Polk LSiFX
Side surrounds: Fxi5
Center: (2)polk LSiC's
Sub: svs pb-13 rosenut
Hd-Dvd: toshiba xa-2
Blue Ray: oppo bdp83se
Projector: sony vw60
Screen: Da-Lite 106"
APC S20 Power conditioner
Rears: Polk LSiFX
Post edited by BAD ASP on
So you want to debug a program that crashes? Free download, Microsoft Visual Studio Express. Then again, I don't know how much good it will do you to debug it. What software is it that crashes?
Great question Sami. What are you doing when you get debug errors.
engtazengtaz
which programs are you running that's causing trouble? IE?? i would start by downloading the latest drivers first from MicroSoft..Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
If you don't know what application it is, look into 'Control Panel->Administrative Tools->Event Viewer' and select 'Application'. You will see the crash there as an error.
I simply ignore and click no. You'll have no idea what to debug. IMO
I am a contractor viewing plans and specifications, it happens when I open pdf files mostly.Home Theater
Rears: Polk LSiFX
APC S20 Power conditioner -
thanks for responding y'all.Home Theater
Rears: Polk LSiFX
You might try uninstalling Adobe and reinstalling the latest version....
http://www.adobe.com/products/acrobat/readstep2.html
Or if your trying to view the pdf's within a browser and its causing problems just right click and save the file to your computer and open it that wayTesting
Testing
Testing -
If the errors are not solved by updating Adobe, I would suggest running memory diagnostics on your computer.
I was reluctant to uninstall / reinstall adobe but I took the suggestion and did it. This seems to have solved the problem.......at least for now. Thanks again..all
mikeHome Theater
Rears: Polk LSiFX
In Internet Explorer click tools, Internet options, Advanced Tab, and then check 'Disable script debugging' in both IE and 'other' apps.
bdaley- that did the trick, thanks.
Hopefully debugging "turn off" doesn't store bugs in my computer eventually shutting it down.Home Theater
Rears: Polk LSiFX
