computer help
edited June 2008 in The Clubhouse
Anybody out there know a download that will help solve this:
I keep getting runtime errors and the prompt asks if I would like to debug. I say yes and it takes me to a dialogue box that shows an error line and a continue or break option. I press continue and nothing happens. I press break and a line appears and then nothing happens. I then press cancel and it asks me if I want to stop debugging. I don't know if I am debugging because nothing happens. This is on my work computer and its becoming a real pain in the ****. I googled run time error debug and there are a number of free downloads to assist but I am wary of which are useful and which are disasters.
Any help would be greatly appreciated!!!
Amp: sunfire cinema grand signature 5ch 425 wpc
Side surround amp: Sunfire 2 X 300
Processor: sunfire theater grand V
Fronts:: polk sda-srs 1.2
Rears: Polk LSiFX
Side surrounds: Fxi5
Center: (2)polk LSiC's
Sub: svs pb-13 rosenut
Hd-Dvd: toshiba xa-2
Blue Ray: oppo bdp83se
Projector: sony vw60
Screen: Da-Lite 106"
APC S20 Power conditioner
Post edited by BAD ASP on
Welcome!
    edited June 2008
    So you want to debug a program that crashes? Free download, Microsoft Visual Studio Express. Then again, I don't know how much good it will do you to debug it. What software is it that crashes?
    edited June 2008
    Great question Sami. What are you doing when you get debug errors.
    engtaz
    engtaz
    edited June 2008
    which programs are you running that's causing trouble? IE?? i would start by downloading the latest drivers first from MicroSoft..
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
    edited June 2008
    If you don't know what application it is, look into 'Control Panel->Administrative Tools->Event Viewer' and select 'Application'. You will see the crash there as an error.
    edited June 2008
    I simply ignore and click no. You'll have no idea what to debug. IMO
    edited June 2008
    I am a contractor viewing plans and specifications, it happens when I open pdf files mostly.
    Rears: Polk LSiFX
    edited June 2008
    thanks for responding y'all.
    Rears: Polk LSiFX
    edited June 2008
    You might try uninstalling Adobe and reinstalling the latest version....
    http://www.adobe.com/products/acrobat/readstep2.html
    Or if your trying to view the pdf's within a browser and its causing problems just right click and save the file to your computer and open it that way
    Testing
    Testing
    Testing
    edited June 2008
    If the errors are not solved by updating Adobe, I would suggest running memory diagnostics on your computer.
    edited June 2008
    I was reluctant to uninstall / reinstall adobe but I took the suggestion and did it. This seems to have solved the problem.......at least for now. Thanks again..all
    mike
    Rears: Polk LSiFX
    edited June 2008
    In Internet Explorer click tools, Internet options, Advanced Tab, and then check 'Disable script debugging' in both IE and 'other' apps.
    edited June 2008
    bdaley- that did the trick, thanks.
    Hopefully debugging "turn off" doesn't store bugs in my computer eventually shutting it down.
    Rears: Polk LSiFX
Welcome!
Welcome!
