computer help
BAD ASP
BAD ASP Posts: 361
edited June 2008 in The Clubhouse
Anybody out there know a download that will help solve this:
I keep getting runtime errors and the prompt asks if I would like to debug. I say yes and it takes me to a dialogue box that shows an error line and a continue or break option. I press continue and nothing happens. I press break and a line appears and then nothing happens. I then press cancel and it asks me if I want to stop debugging. I don't know if I am debugging because nothing happens. This is on my work computer and its becoming a real pain in the ****. I googled run time error debug and there are a number of free downloads to assist but I am wary of which are useful and which are disasters.
Any help would be greatly appreciated!!!
Amp: sunfire cinema grand signature 5ch 425 wpc
Side surround amp: Sunfire 2 X 300
Processor: sunfire theater grand V
Fronts:: polk sda-srs 1.2
Rears: Polk LSiFX
Side surrounds: Fxi5
Center: (2)polk LSiC's
Sub: svs pb-13 rosenut
Hd-Dvd: toshiba xa-2
Blue Ray: oppo bdp83se
Projector: sony vw60
Screen: Da-Lite 106"
APC S20 Power conditioner
Post edited by BAD ASP on
  • Sami
    Sami Posts: 4,634
    edited June 2008
    So you want to debug a program that crashes? Free download, Microsoft Visual Studio Express. Then again, I don't know how much good it will do you to debug it. What software is it that crashes?
  • engtaz
    engtaz Posts: 7,669
    edited June 2008
    Great question Sami. What are you doing when you get debug errors.
    engtaz
    engtaz
  • devani
    devani Posts: 1,497
    edited June 2008
    which programs are you running that's causing trouble? IE?? i would start by downloading the latest drivers first from MicroSoft..
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • Sami
    Sami Posts: 4,634
    edited June 2008
    If you don't know what application it is, look into 'Control Panel->Administrative Tools->Event Viewer' and select 'Application'. You will see the crash there as an error.
  • MKZ
    MKZ Posts: 1,068
    edited June 2008
    I simply ignore and click no. You'll have no idea what to debug. IMO
  • BAD ASP
    BAD ASP Posts: 361
    edited June 2008
    I am a contractor viewing plans and specifications, it happens when I open pdf files mostly.
    Rears: Polk LSiFX
  • BAD ASP
    BAD ASP Posts: 361
    edited June 2008
    thanks for responding y'all.
    Rears: Polk LSiFX
  • Systems
    Systems Posts: 14,873
    edited June 2008
    You might try uninstalling Adobe and reinstalling the latest version....
    http://www.adobe.com/products/acrobat/readstep2.html
    Or if your trying to view the pdf's within a browser and its causing problems just right click and save the file to your computer and open it that way
    Testing
    Testing
    Testing
  • Sami
    Sami Posts: 4,634
    edited June 2008
    If the errors are not solved by updating Adobe, I would suggest running memory diagnostics on your computer.
  • BAD ASP
    BAD ASP Posts: 361
    edited June 2008
    I was reluctant to uninstall / reinstall adobe but I took the suggestion and did it. This seems to have solved the problem.......at least for now. Thanks again..all
    mike
    Rears: Polk LSiFX
  • bdaley6509
    bdaley6509 Posts: 1,167
    edited June 2008
    In Internet Explorer click tools, Internet options, Advanced Tab, and then check 'Disable script debugging' in both IE and 'other' apps.
  • BAD ASP
    BAD ASP Posts: 361
    edited June 2008
    bdaley- that did the trick, thanks.
    Hopefully debugging "turn off" doesn't store bugs in my computer eventually shutting it down.
    Rears: Polk LSiFX
