RC60i vs RC65i
What's the difference between the RC60i and RC65i besides their shape and price?
Can the RC60i be used in-ceiling as front speakers in a 5.1 setup?
Can the RC65i be used in-ceiling?
Post edited by Tampico on
Did you mean can the RC60i's be used in-wall for fronts? I don't think you'd want your fronts in ceiling. You can mount either one where ever you like. The round design are typically for ceiling and more for ambience I would think. The rectangular design is probably a better design sonically. I went with the RC85i's all around and they are much better than I had anticipated. Check out the price,
http://cgi.ebay.com/New-Polk-Audio-RC85I-In-Wall-In-Ceiling-Speakers-PAIR_W0QQitemZ120211420765QQihZ002QQcategoryZ14994QQssPageNameZWDVWQQrdZ1QQcmdZViewItem or the Rci65's,
http://cgi.ebay.com/New-Polk-Audio-RC65I-In-Wall-In-Ceiling-Speakers-PAIR_W0QQitemZ230213444421QQihZ013QQcategoryZ14994QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Those prices are hard to beat. At that price you might as well go with the 85i's.
Or if you have to go in-ceiling for the rears, go with the RC85i's in the front and RC80i's in the rear,
http://cgi.ebay.com/New-Polk-Audio-RC80I-In-Wall-In-Ceiling-Speakers-NR_W0QQitemZ140199321114QQihZ004QQcategoryZ14994QQssPageNameZWDVWQQrdZ1QQcmdZViewItem2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
good suggestion, but a little pricey.
