outlaw
toddco
I have a outlaw M200 that will not power on. After pluging in a diffrent CHn...
still no life. It has done it before but i just polled the intercon... and she came to life. Any ideas of things i can check, do? thanks
RTi12's:D
CSi5
FXi5
CSi3
PB12+2 :cool:
Sony STR-DA2ES
Outlaw M200 x3
SMS 1
Signal Ultra
Sig.2 Inters.
PS 3
Xbox360 Elite
PHILLIPS 42" PLAS. 1080i
Monster 5100 SS
CSi5
FXi5
CSi3
PB12+2 :cool:
Sony STR-DA2ES
Outlaw M200 x3
SMS 1
Signal Ultra
Sig.2 Inters.
PS 3
Xbox360 Elite
Monster 5100 SS
Post edited by toddco on
Give Outlaw Audio a call & let them help you get it repaired.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Try cycling the power on options switch on the back. There's an issue with these amps that has been discussed on the Outlaw forums where the switch gets a little dirty and doesn't make contact, which prevents the amp from powering on.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Check the fuse! Might be too simple but fuses do go out occasionally on their own.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
sounds like the interconnect is making it go into protect mode.. replace the interconnect and see if that helps.PolkFest 2012, who's going>?
Dammit!!! I just ordered 2 of these today! NOW I find out they have issues:mad:I refuse to argue with idiots, because people can't tell the DIFFERENCE!
who said they have issues? maybe his is an isolated case? Have you heard of anyone else having this same problem?
Relax, I had mine for a year & never had any problems with it. I since passed it on to Willow & as far as I know he has had no problems with it.
Then again I never used the switch I just left it in standby to turn on automatically when it got a signal.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
My previous flipout had to do with dkg's post(#3). I may be getting p.o.'d for nuthin'.
I figured with all the members on here that have them, they were a safe bet. We'll see.
BTW, Outlaws' coming out with new preamps in the fall. Don't know how often component co.'s come out with new lines. Hopefully, they'll address the HD formats for Dolby & DTSI refuse to argue with idiots, because people can't tell the DIFFERENCE! -
I had 8 M200's at one time. I had a 9th one that had some issues and another CP member was up to the task of attempting to fix it. I had one that the power option switch was a little dirty, and a shot of CAIG fixed it. Every once in a while I would be moving them around and I would bump the power option switch on one and get it in-between settings, and it wouldn't power on. Move the switch back-and-forth a couple of times, and all is good. I think they changed the switch on the M2200's.
Just a minor weak point on these amps, probably the only weak point. I wouldn't get too worried about it.DKG999
Well i turned the power switch on and lowe and behold its fine. I have had it not turn on before and just played with it and it came on. Thanks for the replys. And yes i feel like a dumm ****:eek:RTi12's:D
CSi5
FXi5
CSi3
PB12+2 :cool:
Sony STR-DA2ES
Outlaw M200 x3
SMS 1
Signal Ultra
Sig.2 Inters.
PS 3
Xbox360 Elite
Monster 5100 SS
