outlaw
toddco
toddco Posts: 147
edited June 2008 in Electronics
I have a outlaw M200 that will not power on. After pluging in a diffrent CHn...
still no life. It has done it before but i just polled the intercon... and she came to life. Any ideas of things i can check, do? thanks:confused:
RTi12's:D
CSi5
FXi5
CSi3
PB12+2 :cool:
Sony STR-DA2ES
Outlaw M200 x3
SMS 1
Signal Ultra
Sig.2 Inters.
PS 3
Xbox360 Elite
PHILLIPS 42" PLAS. 1080i
Monster 5100 SS
Post edited by toddco on
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2008
    Give Outlaw Audio a call & let them help you get it repaired.
  • dkg999
    dkg999 Posts: 5,647
    edited June 2008
    Try cycling the power on options switch on the back. There's an issue with these amps that has been discussed on the Outlaw forums where the switch gets a little dirty and doesn't make contact, which prevents the amp from powering on.
    DKG999
  • hockeyboy
    hockeyboy Posts: 1,428
    edited June 2008
    Check the fuse! Might be too simple but fuses do go out occasionally on their own.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • danger boy
    danger boy Posts: 15,722
    edited June 2008
    sounds like the interconnect is making it go into protect mode.. replace the interconnect and see if that helps.
    PolkFest 2012, who's going>?
  • obieone
    obieone Posts: 5,077
    edited June 2008
    Dammit!!! I just ordered 2 of these today! NOW I find out they have issues:mad:
  • danger boy
    edited June 2008
    obieone wrote: »
    who said they have issues? maybe his is an isolated case? Have you heard of anyone else having this same problem? :confused:
  • cfrizz
    edited June 2008
    Relax, I had mine for a year & never had any problems with it. I since passed it on to Willow & as far as I know he has had no problems with it.
    Then again I never used the switch I just left it in standby to turn on automatically when it got a signal.
  • obieone
    edited June 2008
    My previous flipout had to do with dkg's post(#3). I may be getting p.o.'d for nuthin'.
    I figured with all the members on here that have them, they were a safe bet. We'll see.
    BTW, Outlaws' coming out with new preamps in the fall. Don't know how often component co.'s come out with new lines. Hopefully, they'll address the HD formats for Dolby & DTS
  • dkg999
    dkg999 Posts: 5,647
    edited June 2008
    I had 8 M200's at one time. I had a 9th one that had some issues and another CP member was up to the task of attempting to fix it. I had one that the power option switch was a little dirty, and a shot of CAIG fixed it. Every once in a while I would be moving them around and I would bump the power option switch on one and get it in-between settings, and it wouldn't power on. Move the switch back-and-forth a couple of times, and all is good. I think they changed the switch on the M2200's.
    Just a minor weak point on these amps, probably the only weak point. I wouldn't get too worried about it.
    DKG999
  • toddco
    toddco Posts: 147
    edited June 2008
    Well i turned the power switch on and lowe and behold its fine. I have had it not turn on before and just played with it and it came on. Thanks for the replys. And yes i feel like a dumm ****:eek:
    RTi12's:D
    CSi5
    FXi5
    CSi3
    PB12+2 :cool:
    Sony STR-DA2ES
    Outlaw M200 x3
    SMS 1
    Signal Ultra
    Sig.2 Inters.
    PS 3
    Xbox360 Elite
    Monster 5100 SS
