RTA11TL Crossover
chekov
chekov Posts: 7
edited June 2008 in Vintage Speakers
I'm thinking about replacing the capacitors in my RTA11TL crossovers.
Does anyone know the values?
I popped it open to check, but the yellow cap (in parallel with a 12mf electrolytic) is unmarked. I'm thinking of replacing this pair with a single metalized poly if possible.
I found a thread on RTA11T upgrade to "TL" which hinted that this may be 16mf (total) but I'm not sure.
Also- the resistor is unmarked.
Has anyone done a crossover update on this speaker?
  • Face
    Face Posts: 14,340
    edited June 2008
  • chekov
    chekov Posts: 7
    edited June 2008
    16mf mylar in the tweeter's signal path...
    Looks like mine have a 12mf electrolytic + 4 mf mylar (in parallel).
    I'm guessing that a single 16mf metalized poly would be an improvement.
  • ben62670
    ben62670 Posts: 15,969
    edited June 2008
    Yes a single 16uf is better than the 12 and 4 tied together.
    Ben
  • chekov
    chekov Posts: 7
    edited June 2008
    I was referring to how Polk wired up my crossovers-
    they have a 12mf electro soldered in parallel with the 4mf mylar - the leads are soldered together. These are the two I'm thinking of replacing with a single 16mf.
    There is another 12mf in parallel with the resistor- for that one, I'm planning to use another 12mf poly.
    (also a 34mf poly for the woofer)
    Thanks.
  • ben62670
    edited June 2008
    You're right;)
    Have fun with the upgrade. I am doing my monitor 7's Monday:)
    Ben
    Ben
