98 Porsche Boxster Dash Speakers
M124
Can i fit 5-1/4 speakers in my Boxster's dash openings without an extreme amount of modification to dash ?
Post edited by M124 on
Most likely you will have to cut metal and up in the dash area its not easy due to the window angle, from what Crutchfield says you have 4" up there, so you would have to take out up to 1.25" of metal total....depending on how the 4"s are mounted...Even with the 4"s carried they say they are a modified fit.
Try here ---> http://www.polkaudio.com/caraudio/fitguide/index.phppolkaudio sound quality competitor since 2005
Confirms Crutchfield....
