How power outages affect my HK 635
Ern Dog
I live up in the mountains and for what ever reason my electricity goes off fairly regularly. Every time this happens the settings on my HK AVR635 revert back to default settings and I have to re-enter in all my settings (speaker sizes, channel adjustments, cross-overs, etc). This is such a pain in the ****. Does this happen to everyone else too? Does anyone know a way to get around this?
Post edited by Ern Dog on
no it doesn't happen to me.. since our power rarely goes out.. can you add a backup battery power supply like the ones used for computers? it would tick me off if that happen to me as often as it sounds like it's happening to you..
as complex as AVR's and pre amps are to configure, it would be a big PITA for sure.
It takes me well over an hour to reconfigure all the settings in my pre amp if it should be reset. something I truly hate doing.PolkFest 2012, who's going>?
put the HK, only the HK on a Uninterrupted Power Supply
it will give you time to shut it down properly whenpower goes off suddenlymy 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
That was the main gripe I had about my 635, I think it happens to alot of people, Drove me nuts having to get the mic and tripod out to re-run the EZ-EQ every time the power blinked.Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar -
That Belkin PureAv is nice, but at $400, it is worth more than the HK is.
You can usually find it for half of that on Amazon. I believe I may have even paid under $200."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Ive got an HK 525. When my power goes out (infrequently), I lose all my settings in my AVR as well. I assumed it was a dead internal battery, and ordered a new one from HK for cheep. WHen I got it in the mail, I realized that this wasn't a simple fix - I thought I would be able to easily swap them out like a watch. Turns out that the battery has to be soldered. So, I didn't go forward with the fix and to this day I just bite the bullet and reprogram it when I need to.Do you hear that buzzing noise?
Monster Jam wrote: »Ive got an HK 525. When my power goes out (infrequently), I lose all my settings in my AVR as well. I assumed it was a dead internal battery, and ordered a new one from HK for cheep. WHen I got it in the mail, I realized that this wasn't a simple fix - I thought I would be able to easily swap them out like a watch. Turns out that the battery has to be soldered. So, I didn't go forward with the fix and to this day I just bite the bullet and reprogram it when I need to.
Interesting. I'm going to call HK tomorrow and get more info about this internal battery deal. -
So, I called HK today and they indicated that there is a capacitance network to retain memory settings, which needs to be replaced. My HK has a 2 year warranty, so this fix will be covered.
Off to the shop & cross my fingers it's that easy. -
that's good news... hope the fix works.. and you don't have that problem anymore. I know how annoying it can be.PolkFest 2012, who's going>?
I guess I am too late with the fix suggestion
Yes, there is a capacitor network (usually 3 caps) feeding the memory chip. One cap is fairly large and usually it blows. 95% chance that it's your problem. However, sometimes the actual memory chip is dead - I had the capacitor problem in my 520, and the chip was dead in 510. Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
hope I don't have to face that problem....my HK is running without a problem for the last year..Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
No wonder my "battery" didn't look like a "battery". It was a friggen cap. Sheesh.Do you hear that buzzing noise?
