Help, Math Geeks!!
wingnut4772
wingnut4772 Posts: 7,519
edited May 2008 in The Clubhouse
I have a wall that measures 8' high by 13' wide. I would like to paint a checkerboard pattern on this wall in .... Oh say about 20 to 24" squares. How do I figure out exactly what size the squares should be so they all fit evenly on the wall with no (or undiscernable) fudging on the end or bottom rows?
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    All I can help with at the moment is paint the whole wall the easy color, and paint the other checkers after. No sleep has turned me into a Zombie!
    24 x 22 1/4
    Ben
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2008
    Or if you felt it needed to be square boxes, I guess you could use a third contrasting color behind the squares boxes.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • greg2350
    greg2350 Posts: 544
    edited May 2008
    Ok I asked my dad him being a math whiz he says you would have to make the squares 12" x 12". He says the problem is the odd number width 24" would give you a even number in feet.
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
  • tcrossma
    tcrossma Posts: 1,301
    edited May 2008
    Do the squares have to be the same space apart vertically and horizontally?
    You don't have a perfectly proportional area (8x13) so something is going to have to give here. Either the squares are going to have to be something other than square, the space between them is going to have to be uneven horizontally vs. vertically, or they are going to get chopped off on the sides or bottom.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • shack
    shack Posts: 11,154
    edited May 2008
    0bviously 12" squares would work. 16" squares would work verically (6) but not horizontally (9.75). 24" s also would work vertically (4) but not horizontally (6.5).
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited May 2008
    12 (12x12) squares acrossed, starting and ending 6 inches from both side walls will center the wall and look good with the floor to ceiling squares 8 high.
  • BIZILL
    BIZILL Posts: 5,432
    edited May 2008
    center the checkerboard and then paint a border?
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • unc2701
    unc2701 Posts: 3,587
    edited May 2008
    13 is prime, so the only solution is 1 foot for true squares....
    HOWEVER, I doubt that it's exactly 13 feet by 8 feet, so your best bet is to get the exact measurement in inches, then see how much you'd have to "cheat".
    Ben62670's 24 x 22 1/4 is going to be close enough that no one will notice that they're not really square.
    Backburner:Krell KAV-300i
  • amulford
    amulford Posts: 5,020
    edited May 2008
    If its'a true 8 ft x 13 ft, Come up 4 ft and that will be the top and bottom of that row. The middle column should center at 6'6" ( the side would be at 7'). Draw lines at those dimensions and block it out @ 12" squares. That should work out. 2' squares won't work out, and while Ben's dimensions are as close as you can get, you can see an 1 3/4" difference in a figure that small, IMHO
  • wingnut4772
    edited May 2008
    OK. I am scratching my head still but thanks guys. Maybe I will think of something else.:p
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • wingnut4772
    edited May 2008
    Here's a couple of pics of about what I want. One of the walls does not look square yet the squares do.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Early B.
    Early B. Posts: 7,900
    edited May 2008
    Just out of curiosity, wing, have you studied feng shui?
    "God grooves with tubes."
  • wingnut4772
    edited May 2008
    Early B. wrote: »
    Nope.
    Here's another one with lines between the squares which I kinda like.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • unc2701
    edited May 2008
    Those "squares" aren't exactly square. In the last one, they cheat the top row. In the left one on your previous post, they cheat the bottom row.
    Cheating the bottom row is a good way to do it. Since the baseboard will break things up anyway, no one will notice. So divide the horizontal into equal sizes, then use the same sizes for the vertical, with any remainder (or shortage) going into the bottom row.
  • steveinaz
    steveinaz Posts: 19,546
    edited May 2008
    I did a DIY project in our family room that involved cutting large peices of 1/4" plywood into different size squares/rectangles and upholstering them with a neat old Spanish/Southwest fabric. The fabric was leftovers from pillows Bev had made, so everything coordinates. Guests always ask me where I bought them...
  • wingnut4772
    edited May 2008
    steveinaz wrote: »
    I thought of doing that as well. My whole idea is to make the wall behind the bed the 'feature wall'. How difficult a project was that?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • steveinaz
    edited May 2008
    It's very easy. I simply cut the boards in the shapes I wanted, then wrapped the fabric around them; staple-gunned and hung. Just run a fine file over your cuts so the fabric looks smooth where it wraps over the edge. You can even add some foam behind the fabric to make it more 3-D.
    A real neat idea involves taking 2x4 pieces, cut the size of bricks, and upholstering them and hanging in different areas in small "groups." I haven't tried this one yet, but I will soon.
    You can also use styrofoam backing instead of wood, there's a zillion variations and ideas you can do.
    Have you considered the faux tin stuff? I just did our complete kitchen back-splash with faux tin (polymer--Home depot by the kitchen stuff) in an antiqued gold color, it came out really cool (looks very rich against our cherry cabinets) and far eaiser to work with than tin.
    When I get home tonight I'll throw some pics up.
  • Imperitor
    Imperitor Posts: 235
    edited May 2008
    Do the squares need to be symmetrical or can they be a little taller then they are wide? Does it need to fill the entire wall or can there gaps on the sides? That would make it easier.
    7.1 HOME THEATER:
    Center: CSi3
    Front: RTi10
    Surround: RTi A3
    Rear Surround: RTi4
    Subwoofer: Mirage Omni S10
    TV: Sharp Aquos 42" 1080p LCD
    Receiver: Onkyo TX-SR805
    Blu-Ray Player / CD Player / DVD Player / Media Server / Game Console / Best money I've ever spent: 60GB PS3
  • wingnut4772
    edited May 2008
    Imperitor wrote: »
    I would like them to fill the wall and be square. I would rather fudge a bottom or end row to achieve that that have them be off.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Imperitor
    edited May 2008
    I would personally go with 24" high, 26" wide squares, 6 squares horizontally and 4 squares vertically. They won't be perfectly square but this will avoid messy fractions.
    The next best option would be to go with 19.5" squares. They would fit perfectly horizontally and vertically you would only need to shorten the top or bottom row by 1.5". 8 squares horizontally, 5 squares vertically.
    Hope my geekyness helps.
    7.1 HOME THEATER:
    Center: CSi3
    Front: RTi10
    Surround: RTi A3
    Rear Surround: RTi4
  • amulford
    edited May 2008
    That would do it, just leave the altered row on the bottom and no one will notice.
    I like Steve's ideas, gives more of a statement and dimensionality to it...
  • SKsolutions
    SKsolutions Posts: 1,820
    edited May 2008
    Having the squares be asymmetric and dissimilar will add a warmth and comfort. Having them be perfect and the same, will cool and structure the room. If it's a bedroom, I'd do the former. Bathroom, the latter.
    Good luck with the project.
    -Ignorance is strength -
  • steveinaz
    edited May 2008
    See the below picture of our family room. The 3 squares over the tv are the plywood/fabric squares I made:
  • Gadabout
    Gadabout Posts: 1,072
    edited May 2008
    While not solving the square size problem, this would add some dimension...
    You don't have to use the same type of paint finish. By not having the same finish in all the squares you can add some texture / dimensioality to the wall.
    My choices if I were doing that would be Matte, Flat Enamel and Satin. Of couse the finsish would also depend on the wall location and presence of kids with drawing abilities.
    Haven't done the squares with different finsihses, but I have done a Matte / Flat base and painted in deatils in Satin. Made it look great and a little 3d.
    Paint Finishes
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • wingnut4772
    edited May 2008
    Thanks for all the suggestions guys. I still have two weeks to mull everything over. O may not even go this route but I am learning a lot.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
