Help, Math Geeks!!
wingnut4772
I have a wall that measures 8' high by 13' wide. I would like to paint a checkerboard pattern on this wall in .... Oh say about 20 to 24" squares. How do I figure out exactly what size the squares should be so they all fit evenly on the wall with no (or undiscernable) fudging on the end or bottom rows?
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
All I can help with at the moment is paint the whole wall the easy color, and paint the other checkers after. No sleep has turned me into a Zombie!
24 x 22 1/4Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Or if you felt it needed to be square boxes, I guess you could use a third contrasting color behind the squares boxes.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Ok I asked my dad him being a math whiz he says you would have to make the squares 12" x 12". He says the problem is the odd number width 24" would give you a even number in feet.TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
Do the squares have to be the same space apart vertically and horizontally?
You don't have a perfectly proportional area (8x13) so something is going to have to give here. Either the squares are going to have to be something other than square, the space between them is going to have to be uneven horizontally vs. vertically, or they are going to get chopped off on the sides or bottom.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
0bviously 12" squares would work. 16" squares would work verically (6) but not horizontally (9.75). 24" s also would work vertically (4) but not horizontally (6.5)."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
12 (12x12) squares acrossed, starting and ending 6 inches from both side walls will center the wall and look good with the floor to ceiling squares 8 high.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
center the checkerboard and then paint a border?
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
13 is prime, so the only solution is 1 foot for true squares....
HOWEVER, I doubt that it's exactly 13 feet by 8 feet, so your best bet is to get the exact measurement in inches, then see how much you'd have to "cheat".
Ben62670's 24 x 22 1/4 is going to be close enough that no one will notice that they're not really square.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
If its'a true 8 ft x 13 ft, Come up 4 ft and that will be the top and bottom of that row. The middle column should center at 6'6" ( the side would be at 7'). Draw lines at those dimensions and block it out @ 12" squares. That should work out. 2' squares won't work out, and while Ben's dimensions are as close as you can get, you can see an 1 3/4" difference in a figure that small, IMHO
OK. I am scratching my head still but thanks guys. Maybe I will think of something else.:pSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Here's a couple of pics of about what I want. One of the walls does not look square yet the squares do.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Just out of curiosity, wing, have you studied feng shui?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Nope.
Here's another one with lines between the squares which I kinda like.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Those "squares" aren't exactly square. In the last one, they cheat the top row. In the left one on your previous post, they cheat the bottom row.
Cheating the bottom row is a good way to do it. Since the baseboard will break things up anyway, no one will notice. So divide the horizontal into equal sizes, then use the same sizes for the vertical, with any remainder (or shortage) going into the bottom row.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
I did a DIY project in our family room that involved cutting large peices of 1/4" plywood into different size squares/rectangles and upholstering them with a neat old Spanish/Southwest fabric. The fabric was leftovers from pillows Bev had made, so everything coordinates. Guests always ask me where I bought them...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I thought of doing that as well. My whole idea is to make the wall behind the bed the 'feature wall'. How difficult a project was that?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
It's very easy. I simply cut the boards in the shapes I wanted, then wrapped the fabric around them; staple-gunned and hung. Just run a fine file over your cuts so the fabric looks smooth where it wraps over the edge. You can even add some foam behind the fabric to make it more 3-D.
A real neat idea involves taking 2x4 pieces, cut the size of bricks, and upholstering them and hanging in different areas in small "groups." I haven't tried this one yet, but I will soon.
You can also use styrofoam backing instead of wood, there's a zillion variations and ideas you can do.
Have you considered the faux tin stuff? I just did our complete kitchen back-splash with faux tin (polymer--Home depot by the kitchen stuff) in an antiqued gold color, it came out really cool (looks very rich against our cherry cabinets) and far eaiser to work with than tin.
When I get home tonight I'll throw some pics up.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Do the squares need to be symmetrical or can they be a little taller then they are wide? Does it need to fill the entire wall or can there gaps on the sides? That would make it easier.7.1 HOME THEATER:
Center: CSi3
Front: RTi10
Surround: RTi A3
Rear Surround: RTi4
Subwoofer: Mirage Omni S10
TV: Sharp Aquos 42" 1080p LCD
Receiver: Onkyo TX-SR805
Blu-Ray Player / CD Player / DVD Player / Media Server / Game Console / Best money I've ever spent: 60GB PS3 -
I would like them to fill the wall and be square. I would rather fudge a bottom or end row to achieve that that have them be off.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
I would personally go with 24" high, 26" wide squares, 6 squares horizontally and 4 squares vertically. They won't be perfectly square but this will avoid messy fractions.
The next best option would be to go with 19.5" squares. They would fit perfectly horizontally and vertically you would only need to shorten the top or bottom row by 1.5". 8 squares horizontally, 5 squares vertically.
Hope my geekyness helps.7.1 HOME THEATER:
Center: CSi3
Front: RTi10
Surround: RTi A3
Rear Surround: RTi4
That would do it, just leave the altered row on the bottom and no one will notice.
I like Steve's ideas, gives more of a statement and dimensionality to it... -
Having the squares be asymmetric and dissimilar will add a warmth and comfort. Having them be perfect and the same, will cool and structure the room. If it's a bedroom, I'd do the former. Bathroom, the latter.
Good luck with the project.-Ignorance is strength - -
See the below picture of our family room. The 3 squares over the tv are the plywood/fabric squares I made:Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
While not solving the square size problem, this would add some dimension...
You don't have to use the same type of paint finish. By not having the same finish in all the squares you can add some texture / dimensioality to the wall.
My choices if I were doing that would be Matte, Flat Enamel and Satin. Of couse the finsish would also depend on the wall location and presence of kids with drawing abilities.
Haven't done the squares with different finsihses, but I have done a Matte / Flat base and painted in deatils in Satin. Made it look great and a little 3d.
Paint FinishesWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
Thanks for all the suggestions guys. I still have two weeks to mull everything over. O may not even go this route but I am learning a lot.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
