Help me pick my surrounds
I'm going to finally move the Boston bookshelf's I'm using and try to match things up right. A little about my system: 3.1tl's with Dennon 6600 mono's for the bottom end and 4400 mono's for the top. The center is a CS400. I have a POA 5000 6 channel amp that is bridged for 200 wpc which is driving the center and that leaves 100wpc for the surrounds. I was looking at the original FX series but is there something else out there? I don't have anything against the FX's I just want to know all of my options. I have all of this and my 36" Wega jammed in my 11x11computer room for the meantime but as soon as I get off of my butt and finish the basement or upstairs it will move. thanks
SDS-400, SDA-1B, SVS 20-39pc+, B&K Ref 50, Denon 2900
Post edited by kelley on
Your options are fx.....fx/500's or fx/1000's.You could get the new ones........
Unless your looking for mono's,then a good pair of rt35i's would be sweet.Dan
I'd like a pair of the FX's but even the supply on EBAY has dried up.SDS-400, SDA-1B, SVS 20-39pc+, B&K Ref 50, Denon 2900
Not quite dry yet...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3019519074&category=14996
The BIN may have been a tad high when there were a number out there, but $600 is around the top end of the old range. If they're mint, could be worth it.
Seller's rating is good to boot (no affiliation)...More later,
Tour...
Vox Copuli
