distance between RTi 10s....
broncsrule21@
broncsrule21@ Posts: 113
edited June 2008 in Speakers
What are the factors that determine how far your front speakers should be apart from each other? Is there a "magic formula"? or is it just a trail and error thing to find out what is best for each individual system??
HT-- Denon avr-2808ci,Emotiva UPA-1s, RTi 10's, CSi A6, ERD-1 surrounds, Vizio P50, Yamaha yst-sw300, DVR hr21, 40g PS3, APC-h15
Downstairs-- Denon avr-3300,Emotiva UPA-2, Toshiba 50" rear projection, Denon 2200 sacd, Emotiva ERM-1s, small Yamaha sub
Post edited by broncsrule21@ on
  • PSOVLSK
    PSOVLSK Posts: 5,371
    edited May 2008
    General rule is to have the speakers the same distance from each other as they are from the listening position. Ex: If you sit 10ft from the speakers place them 10 ft apart. Again, this is a general rule and is not even feasible is some listening areas. Give it a shot and work with toe-in, etc. until you get the best sound.
  • broncsrule21@
    edited May 2008
    Thanks for the advise
  • Hawkeye
    Hawkeye Posts: 1,313
    edited May 2008
    Te Cardas site has some interesting insights on speaker positioning. It helped me get mine very close.
    http://http://www.cardas.com/content.php?area=insights&content_id=27&pagestring=Room+Setup
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • Imperitor
    Imperitor Posts: 235
    edited May 2008
    7.1 HOME THEATER:
    Center: CSi3
    Front: RTi10
    Surround: RTi A3
    Rear Surround: RTi4
    Subwoofer: Mirage Omni S10
    TV: Sharp Aquos 42" 1080p LCD
    Receiver: Onkyo TX-SR805
    Blu-Ray Player / CD Player / DVD Player / Media Server / Game Console / Best money I've ever spent: 60GB PS3
  • dbaldus
    dbaldus Posts: 730
    edited May 2008
    I have also heard the "equilateral triangle" rule, but for me, each side of the triangle is 9 feet! I have heard that if your speakers are further apart from each other than you are from each of the speakers that you are to angle the speakers in, but since they are 9 feet apart from each other, I find it best to angle them in a little bit anyway.
    Has anyone else had this experience?
    2-channel
    Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
    Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2
  • broncsrule21@
    edited May 2008
    This is what it currently looks like --about 14ft between speakers and 15ft to center theater chair. I have the screens off everything because I don't want the cat to ruin them like the my old Infinitys..
    treitz3 Posts: 19,950
    edited May 2008
    Where you took this photo I presume is in your listening position. If my assumption is correct, toe in the right speaker [move the front of the speaker only] so that the tweeter points about 2" away from you right ear. Repeat the same thing for your left speaker and see if this helps.
    VR3 Posts: 29,394
    edited May 2008
    Id move them away from the wall about a 1 ft and a foot closer together, along with Treitz advice...
  • Early B.
    Early B. Posts: 7,900
    edited May 2008
    Along with treitz and Sid's advice, can you place the sub in the corner?
    "God grooves with tubes."
  • broncsrule21@
    edited May 2008
    Yes, I could get the sub in the corner if I followed the advise of bringing in the speakers a little.
    edited May 2008
    Try it and then sit in the sweet spot and give it another listen. Then please get back to us with your observations if you will.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited June 2008
    Kind of unrelated, but you've inspired me to wall mount my TV; I'll have a setup very similar to this soon.
    BTW, Did the above advise help?
  • broncsrule21@
    edited June 2008
    Yes the advice helped. The I think the bass is a litte better with the sub in the corner. Bad news is I have to upgrade my sub cable. The Monoprice I was using wasn't long enough, so I had to go back to an old Monster cable. Now my auto on/off doesn't work as well. Oh well, there is always more tinkering to do.
    Also, my monitor is on a floating stand. It is nice because I can turn it to aim into my kitchen/dining area. I highly recommend it.
