Satellites vs. Floorstanders
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited May 2008
    Okay, maybe I am confused about something. What I am saying is running speaker cables from the amp directly to the speakers like you do when you do not have a sub in play. Then from your second outputs from the preamp running to stereo subs. That sub circuitry would have zero effect on your mains because it is not in the signal path. Then one would have to dial in the subs to work with your mains so at get the very bottom only.
    I have never ran a sub but is this not one way to do it?
    Thanks,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • pearsall001
    pearsall001 Posts: 5,241
    edited May 2008
    well I guess you can sum it up Phil by saying that a good little man (satellite) can beat a bad big man (floorstander), but a good little man can never beat a good big man.
    long live the floorstander!!!!!!!!!!!!
    of course the OP is now totally confused and we went from Circuit City to Esoteric, but it is what we do.:eek:
    RT1
    Almost true Ted, but you left out one very inportant variable. The sub!!!!
    Now it goes like this:
    A good little man along with a good little sub will kick the living sheeeeet out of a good floorstander. The FS wouldn't make it past the 1st round.
    Yeah that poor OP...he probably just went out & bought a Bose system. He probably figured out that we're all nuts around here.
  • Midnite Mick
    edited May 2008
    You bunch of crazies.
    If the OP was smart he'd get the hell out of here before it is too late. Run man run, this is no good for you.:p
    Consonance cd120T
    Usher CP 6311
  • jm1
    jm1 Posts: 618
    edited May 2008
    To answer your question, No, the signal is compromised (degraded) whether its sent first to the sub then to the mains or to the sub out, any electrical circuit/connection can only take away from the signal. The sub just amplifies the signal and plays it, of course its been degraded a bit. No matter how you spin it when integrating a sub you must introduce more variables to the audio signal, still not good news.
    You should have a look at the pro/cons between active and passive crossover implementations. I would rather have an external active crossover rather than an internal passive crossover commonly found in speakers.
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
    tonyb Posts: 33,067
    edited May 2008
    Gotta love the 'ol Polk back and forth.I personnaly agree with Ted,but to a point.Yes you can have monitors and subs and have a kick **** system,heard plenty myself.As in everything audio,comes down to personal taste,waf,your room,budget,yada,yada.Ted is just going down to the nuts and bolts of things,in a purist state of mind,and you guys know he's right.Now,whether you can hear the differences or not,wether you give 2 craps or not,this all may not matter to you anyway,except for what your ears are telling you.So if monitors and subs get your stick up,or be it floorstanders,rock out with your c#$k out boys.:D
  • jm1
    jm1 Posts: 618
    edited May 2008
    tonyb wrote: »
    That the funniest thing I have heard in a long time. Thanks! I needed that.
    Arthur Schopenhauer
  • Midnite Mick
    edited May 2008
    Really? I thought this was much funnier.
    tonyb wrote: »
    Consonance cd120T
    Usher CP 6311
  • pearsall001
    edited May 2008
    To each his own...but floorstanders are nothing more than monitor wanna be's trying (I mean that very loosely) to kick out some real bass!! :D:D:D
  • SlowcarIX
    SlowcarIX Posts: 887
    edited May 2008
    treitz3 wrote: »
    Unless you have an SMS-1. :D
    the sms-1 is no substitude for good sub placement/good sitting position...
    my room bass response was so messed up - it was unfixable with the sms-1...so i moved the mic around and found this :):p:D
    sms-1 has since gone to a new home to help the new owner find the good placement/sitting position
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2008
    audio geeks.............go figure....
    RT1
  • jm1
    jm1 Posts: 618
    edited May 2008
    RT1
    Thanks, considering this is an audio forum.............go figure....
    Arthur Schopenhauer
  • reeltrouble1
    edited May 2008
    your welcome. although its hard to hear you with those loud noise banging sub thingies mucking things up.
    RT1
  • kuntasensei
    kuntasensei Posts: 3,263
    edited May 2008
    gte697h wrote: »
    Hi! I was wondering if anyone had an opinion on whether Floorstanders were better than satellites? For what I've demoed at Circuit City, it seemed like the floorstanders provide better directional bass than a satellites + subwoofer combo.
    Specifications for my setup are, small room, 5.1 home theater, onkyo 705 receiver. Any opinions on pros and cons of satellites vs. floorstanders would be appreciated!
    As you can see from all the previous posts, opinions very wildly on the subject. I'll add my two cents:
    I'm running the Onkyo 705 as well. I went from Polk RTi28 mains (bookshelves) to RTi70 floorstanders when I decided to move the 28s to rear surround duty. However, I would still recommend using a subwoofer with floorstanders. The 705 is a very flexible receiver in that it lets you select crossover points in increments of 10Hz starting down at 40Hz. There is a delicate balance between music performance and movie performance, however, I do feel that there is an advantage to using floorstanders that makes them great for both.
    To get the best blend of deep bass to your subwoofer, look at the low -3dB point of floorstanding speakers and multiply that times 1.5. That gives you a half-octave above the speaker's natural rolloff for the subwoofer to take over bass duties. This point should be well below the crossovers in the speaker itself, so you shouldn't have any overlap. For instance, I'm running my RTi70s at a 60Hz crossover on the 705. This keeps the directionality of musical bass as well as the improved tone, which is the advantage of floorstanders. It also keeps significant sound down to 50Hz in the speaker itself. With most music, I notice little difference between running the 70s full range or running them at 60Hz and letting my SVS 20-39CS+/Samson 1000 rig pick up the slack. With movies, however, there's a vast difference in performance, and I wouldn't run full range floorstanders for that purpose. Because the 705 has such a flexible crossover setting, you can get the most out of floorstanders and still get great movie performance down below their capabilities.
    The other thing that makes the 705 work really well for this is that it has Audyssey MultEQ XT. It will do a very fine equalization of each speaker based on its in-room response across the full range of its capabilities, giving you a great blend to the subwoofer. It also does a good job of detecting acoustic distance to keep the speakers as close in phase with the subwoofer as possible. Something to keep in mind with the 705, however: Onkyo chose to use a 80Hz threshold during Audyssey's crossover detection as "FULL RANGE"... so most bookshelf speakers will likely detect as full range on the Onkyos. After running Audyssey setup, manually change any crossover set to "full range" to 1.5x the speaker's lower -3dB point if you have a subwoofer.
    All that said, you don't "need" floorstanders, especially if your primary use is for movies. I do strongly recommend at least using bookshelf sized speakers instead of "satellites", which are normally small speakers whose specs require them to be run above an 80Hz crossover (which means you will lose bass directionality and hear bass coming from the sub instead of from its corresponding channel, known as "localization"). Most Polk bookshelf speakers work well down to 60Hz, making them ideal for a system with an 80Hz crossover.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • gte697h
    gte697h Posts: 27
    edited May 2008
    Thanks to All for some really good answers. As you'll guessed, I didn't understand half of it which makes me want to learn more :)
    treitz3 wrote: »
    To me? That's the most loaded question of the year. It SO totally depends on what your musical genre is and how loud you listen to it, what your room dimensions are, not to mention what you have feeding it. Then there is that question that might throw a wrench into things....do you want a sub?
    Answer this, we can move on.
    Trietz, I like to listen to classic rock, a lot of Led Zep, rolling stones etc. I like to listen to it fairly loud as well :D My living room is probably 300-350-sqft. I'm inching towards a RTi8 fronts, Csi3 center and Fxi3 for the rears WITH a sub (not sure which one yet :) I will also be using this setup mainly for movies.
    How does this setup sound guys?!
  • ArdyAr
    ArdyAr Posts: 3
    edited June 2008
    I have my Acoustic Zens with a Sunfire sw crossed at 32hz.Sub is hidden and nobody guesses where it's at.Only time you run into directional problems is when you cross over too high.With some speakers you don't have a choice...
    Acoustic Zen Adagios
    Proceed Amp2
    Jeff Rowland Consummate preamp
    Cambridge Audio 840c cd player
    Ariston turntable
    Sunfire sub
