Can an external DAC do SACD 2 Channel?
ben62670
I know many SACD's are dual format, but can an external DAC do the d a c for the SACD layer in 2 channel. I'm pretty sure the answer is no:(
Thanks Guys
Ben
Thanks Guys
Ben
Ben
Ben
Post edited by ben62670 on
Only with HDMI.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
No..~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
No...
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
No such luck for me. My Outlaw only has DVI inputs, Coax, and optical. I have a Sony 400disc DVD changer that does SACD, but in the audio department it is lacking. I just hate to loose the convenience, and have to get another source.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Dependent on your definition of "DAC".
In the traditional sense, there're only a handful on SACD-capable DAC and they're generally super expensive. Not to mention they often require a proprietary SACD transport with a proprietary connection.
However, if you want to do the DSD bitstream decoding external of the player, you can now do it with a DSD-compatible receiver....such as Yamaha's new 663. If you use a player such as Oppo's 980 or 983, both of which can send the naive DSD bitstream using their HDMI output, you can use a receiver like the Yamaha to do the DSD decoding. There're other options, such as receivers from Marantz and Onkyo. The Yamaha 663 will set you back about $400.00 and the Oppo players start at $170.00. -
Thanks Danny. For the limited number of SACD's I can't justify sinking that kinda dough into processing. I have an Outlaw990 dedicated Pre that handles everything else pretty good. I have an Adcom GDA-700 in my near future that will do the DA conversion for my Sony CD, and DVD carousels. I just can't give up the convenience. Someday a nice source may be in my future, but for now I have to look at the big picture.
Ben -
No problem, Ben.
There's no reason that a SACD player, by itself, can't do an excellent job of processing DSD. Aside from the convenience of a single cable passing the DSD bitstream, instead of six separate analog cables for 5.1 multi-channel surround sound, external processing doesn't guarantee better sound quality. OK, maybe better bass management....but an Outlaw ICBM unit (discontinued) can easily fix that.
Edit: Oops....just saw your mention of 2 channel. Nevermind about the surround sound part. -
The Sony DVD is pretty thin sounding. Not just in the bass. I can live with that for now.
Ben -
Perhaps a bit of rail here sorry, but is this like the I-Link with Pioneer?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »Perhaps a bit of rail here sorry, but is this like the I-Link with Pioneer?
Yes. The two ways to transfer DSD digitally are I-link (IEEE 1394) or HDMI. -
To be precise, HDMI v.1.2 or above. You will still need a receiver that can decode DSD even if you have HDMI v.1.2 or above.
