Should I Swap Subs?
DemonAstroth
OK... so my current setup is this:
2 Infinity Kappa Perfect 10.1's (10 inch SVC 350 watts rms each)
They are being powered by my Eclipse 34230 (370 w x 2 rms @ 4 ohm) My amp is not 2 ohm stable.
Now, I've seen a very nice Eclipse SW9122 that I am thinking about getting.
It is a Titanium 12 inch DVC w/ 750 w RMS
Specs:
FS: 22 Hz
Qts: 0.30
DCR: 4ohm, 4ohm
Vas: 3.2 cuft
Xmas (1 way): 1.5"
RMS: 750 w
Max: 1500 w
The reason why I would like to get this is because both of my amps are Eclipse (XA4000 and 34230), I have an Eclipse CD7100, and 1 12" sub will take significantly less room than 2 10's. Having more trunk space is certainly nice.
However, it ultimately comes down to sound. Can one 12 inch compare to 2 10's? Regardless of how good it is. My car is not huge by any means. Infiniti G20t, but I really don't want to be dissapointed by doing something like this.
I can sell both of my subs w/ their box and the amp the eclipse comes up with to make the deal without really spending much. So any advice?
Thanks.
PS: Funny thing I've been thinking about making a thread like this to swap my ALpine SPX177r's for some SR6500's.... but that's another story.
Specs:
FS: 22 Hz
Qts: 0.30
DCR: 4ohm, 4ohm
Vas: 3.2 cuft
Xmas (1 way): 1.5"
RMS: 750 w
Max: 1500 w
Thanks.
Post edited by DemonAstroth on
Hard to say if a single 12 will outperform dual 10's. It depends on the box, the subs and the power. From what youve got listed, Id say you get a 1000 watt amp on the Eclipse 12 and it would probably do a little better than a pair of 10's getting 370 each but it wont be by a ton. Infinity makes pretty sorry speakers but their subs are pretty solid and 740 RMS is pretty solid power as well so the setup you have now is pretty good.polkaudio sound quality competitor since 2005
Thanks.
I wouldn't really change the amp. Is 740 rms for a 750 sub not enough?
I just think that if the sound is comparable, and I can have a smaller box w/ more trunk space it would be worth it.
It feels like a gamble though. -
Just a guess going by what I know and have heard from both brands of subs - with the same amp, youd lose a little output going with the Eclipse but the sound would be better.polkaudio sound quality competitor since 2005
OK...
So I ended up going a complete different route.
I got 2 MM2124's, so saving trunk space is out of the question. The website says .88 ft^3 per sub. This seems pretty small for a 12 inch sub. Now I just gotta go find one that's that small.
The box that they're on is more than 1.5 feet^3 per sub, so I should def switch to a smaller box?
Now I wish my amp had a little more power, as 370 is short of their recommended RMS.
Oh well, we'll see how it sounds.
