LSi9's pooping out
lhbrennan
I have a Marantz sr5002 receiver hooked up to an Emotiva XPA-5 powering my pair of LSi9's, with a low end klipsch sub. It sounds really good.
The problem is, when I play loud music, the system starts to **** out. It usually happens with electronic dance music that is very bass heavy, and the clipping usually starts when I turn up my receiver to 0 or +1.
I was under the impression that this system would be able to perform without strain at a volume higher than i could stand... is there anything that might be causing this? Are the speakers the weak link, or the power amp? Are there any tweaks I could perform to get a little more from it?
Also, would bi-amping the LSi9's help alleviate the strain?
I'm a beginner with all of this so I really appreciate all your commentary/advice!
Also sorry if this is the wrong forum for this thread, I wasn't quite sure...
Post edited by lhbrennan on
Also, I'm usually playing music from my computer or my ipod. I currently have them hooked into the tape and tv inputs. Not sure if that changes anything.
There are limits to everything, you've found the limits of your set up. A real man's amp would help, but even they have limits. Turn it down, your ears will thank you years from now.Political Correctness'.........defined
President of Club Polk -
Try raising the XO on the 9's with serious bass heavy music/HT. Try 80 first, and then 60. The 9's dip real low in impedance on bass notes.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
IIRC, down to 2 ohms.Try raising the XO on the 9's with serious bass heavy music/HT. Try 80 first, and then 60. The 9's dip real low in impedance on bass notes."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
as F1Nut said.. you can't expect speaker's with a 6.5" drivers to give you extreme amounts of bass.. for that you need to add a big beefy subwoofer..PolkFest 2012, who's going>?
They're 5.25".danger boy wrote: »as F1Nut said.. you can't expect speaker's with a 6.5" drivers to give you extreme amounts of bass.. for that you need to add a big beefy subwoofer.."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
They're 5.25".
there you go.. even more of a reason not to expect deep bass out of them..PolkFest 2012, who's going>?
Thanks for all the responses. I started to fiddle more with the marantz receiver settings. A couple questions:
There is a crossover dial on the Klipsch sub, but the receiver seems to be bypassing it or something, because when i turn it, the bass response doesn't change. Does the receiver automatically do this?
Anyway, I changed the speakers settings on the receiver to "small," which according to the manual cuts out everything below a certain frequency from the main speakers, sending it to the sub only. The marantz only lets me choose either 80hz, 100hz.. and so on up. This is not very exact; I would much prefer to use the dial. Anyway, set at 80hz, I have avoided the clipping from before, so at least I'm not damaging the LSi9's. But it seems like theres a hole in the bass response now... in between the frequencies sent to the sub and those sent to the mains. It doesn't feel like the sub is picking up the slack all the way...
Any thoughts? Thanks a lot everyone. -
Turn the crossover dial on the subwoofer all the way up. (defeat it if you can)
If you have an LFE input on your subwoofer, plug the sub cable into that.
Michael
BTW - Welcome to club polk...Mains.............Polk LSi15 (Cherry)
I can't wait for someone to respond to that quote. Lots of people rant about these amps on here. I gotta go get some popcorn.Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W -
I like mine with butter, thanks.Political Correctness'.........defined
Yeah,and that Emotive is having a hard time.Dude,turn it down,as Jessie said,everything has it's limits.That low end sub probably doesn't go much lower than the 9's anyway.Being the curious f#%k that I am,what gave you the impression that getting an amp would allow you to crank on the volume dial ? Get your read on grasshopper.HT SYSTEM-
lsi 9's -
Not only have you reached the limits of your speakers, you are also fliritng with deafness!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I only turn it up that loud when I have a mini dance party in my room! I swear!
Anyway, I thought that clipping was most often the result of underpowered speakers. I'm still a beginner with all this stuff. It seems that some of you think I've reached the limit of the speakers, and some of you think the emotiva is not quite up to what I'm demanding. I guess its a bit of both?
Also, I don't want to discourage anyone who is considering these speakers from making a purchase. They really do sound great. -
Your amp states 450wpc when driving 2 channels at 4ohms, I doubt its your amp.
You amp is fine. Your Speakers are fine. If you want more bass get a better sub.
Get an SVS sub & you'll be all set.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
