GNX124 x2 /boss C700 amp
Systems
Systems Posts: 14,872
edited April 2003 in Car Subwoofer Talk
hiya all
im thinkin abot gettin 2 GNX124 [1 GNX124 for now]wit boss C700 amp? will the amp be good for them ..thx for the replies
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited April 2003
    well... what is the rating of the amp ....
    bridged at 4 ohms rms??...
    bridged at 2 ohms rms (is it even stable at this impedance??)
    stereo 4 ohms rms ??
    stereo 2 ohms rms ??
    post that info and an answer will be forthcoming.
    The Artist formerly known as PoweredByDodge
  • Systems
    edited April 2003
    BOSS C-700 2 Channel MOSFET
    Max power, 2 ohms 600w x 2
    RMS power, 4 ohms 200w x 2
    Bridged power 1200w x 1
    Signal-to-noise ratio 102 dB
    THD 0.01%
    Testing
    Testing
    Testing
  • PoweredByDodge
    edited April 2003
    well.. according to those specs.. it'll work...
    i mean i'm no fan of boss so i cant attest to teh quality of its "woking -ness" but it'll work.
    200 x 2 at 4 wRMS -- so you can put a 4 ohm sub on each channel and you're doing just a hair above the sub's rms rating... which is fine.
    or.. bridge the sucker down to 600 x 1 or whatever it does bridged at 4.... series the subs up to 8 ohms and u'll get that same 200 watts per sub but in mono instead of stereo. (whatever an amp does at 4 ohm stereo.. it'll do double that at 8 ohm bridged... usually 3 times to 4 times that at 2 ohms bridged).
