GNX124 x2 /boss C700 amp
Systems
hiya all
im thinkin abot gettin 2 GNX124 [1 GNX124 for now]wit boss C700 amp? will the amp be good for them ..thx for the replies
Testing
Testing
Testing
Testing
Testing
well... what is the rating of the amp ....
bridged at 4 ohms rms??...
bridged at 2 ohms rms (is it even stable at this impedance??)
stereo 4 ohms rms ??
stereo 2 ohms rms ??
post that info and an answer will be forthcoming.The Artist formerly known as PoweredByDodge -
BOSS C-700 2 Channel MOSFET
Max power, 2 ohms 600w x 2
RMS power, 4 ohms 200w x 2
Bridged power 1200w x 1
Signal-to-noise ratio 102 dB
THD 0.01%Testing
Testing
Testing -
well.. according to those specs.. it'll work...
i mean i'm no fan of boss so i cant attest to teh quality of its "woking -ness" but it'll work.
200 x 2 at 4 wRMS -- so you can put a 4 ohm sub on each channel and you're doing just a hair above the sub's rms rating... which is fine.
or.. bridge the sucker down to 600 x 1 or whatever it does bridged at 4.... series the subs up to 8 ohms and u'll get that same 200 watts per sub but in mono instead of stereo. (whatever an amp does at 4 ohm stereo.. it'll do double that at 8 ohm bridged... usually 3 times to 4 times that at 2 ohms bridged).The Artist formerly known as PoweredByDodge
