Can I (or should I) use FXi3's for 7.1 rear surround?
THXtom
I'm putting together a little bedroom theater for myself and already have a pair of FXi5's for rear surround - I love their bi/dipole sound.
If I want a 7.1 setup....should I add another set of FXi bi/dipoles speakers or will that ruin the sound?
In other words, will two pairs of bi/dipoles sound like conflicting crap in a 20ftx20ft bedroom???
All advice appreciated!
Thanks!
Thanks!
Post edited by THXtom on
In most systems, for 7.1 we recommend using the same model speakers as your L and R surround speakers- so if you already have FXi5's, then use another pair of FXi5's- mounted at the same height.
Regardless they should be properly positioned- two at the sides of the listening area and two behind, forming the correct angles.
Here's a good diagram:
http://www.dolby.com/consumer/home_entertainment/roomlayout2.html-Eric
-Polk Audio -
Just for giggles, what's the rest of your "bedroom" rig?
Agreed.
And thanks for the little Dolby diagram; it's pretty cool how they set that up.
If those are the speakers you have THXtom, use them. They'll sound good. -
i'm still learning about all this surround stuff but if you used bi/dipole speakers in the rear wouldnt that send the sound everywhere but toward you or some sound to you and some straight into a wall?reciever-Yamaha rxv1700
front-RM50t
center-RM30
surrounds-M40
rear surrounds-RM30
velodyne minivee
playstation 3 -
Yes, that's the point of the surround speakers. They should be diffuse (hard to tell where they're coming from) enveloping, so it's fine to have the sound bounce off of all the surrounding surfaces. If you aim the speakers directly at you the sound becomes quite pinpointable.jjeckelxz5 wrote: »i'm still learning about all this surround stuff but if you used bi/dipole speakers in the rear wouldnt that send the sound everywhere but toward you or some sound to you and some straight into a wall?
The front speakers- however should be aimed directly at the listener. Here you want a focused, defined sound. A little different then the diffuse nature of surrounds.
Of course everything in audio is personal preference, some listeners prefer the more direct/pin point sound of a surround speaker aimed directly at the listening area.-Eric
-Polk Audio -
Curious how good Bi-Pole /Di-Pole models are for music...LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
you could absolutely use FXi3 with FXi5, some folks also use a non-surround back speaker, for DVD's that have discreet rear tracks many of these sounds -gunshots, as an example are much more directional, the speakers should be mounted above your head and closer together than you might think.
RT1 -
+1 reeltrouble1. My friend uses them them for side and rear speakers.
engtazengtaz
I use FXi A4s for my sides and rears and it works fine.
If you're running a THX amplifier, then direct radiating rears is the way to go. This diagram is how my HT is setup. I've got fx1000's on the sides and inwalls placed together on the back wall. http://www.thx.com/home/setup/speakers/71.html
